Half-Life Calculation: Radioisotope
The discussion centers around calculating the half-life of a radioisotope based on its activity measurements at two different times. Participants explore the mathematical relationships involved in decay equations and the derivation of half-life, with a focus on applying these concepts to a specific homework problem.
  • Homework-related
  • One participant presents a homework problem involving the activity of a radioisotope measured at two different times.
  • Another participant suggests using the decay constant and provides links to external resources for equations related to half-life calculations.
  • A participant shares the relevant equations for calculating the decay constant and half-life, indicating the need to convert units.
  • One participant confirms their approach to calculating the decay constant and subsequently the half-life.
  • Another participant reports a calculated half-life of 21661 minutes, which they convert to 361 hours.
  • A later reply expresses agreement with the calculated half-life value presented by the previous participant.
While there is agreement on the approach to solving the problem and the calculations presented, the accuracy of the calculated half-life remains unverified by additional participants, leaving some uncertainty in the final value.
Participants do not clarify the assumptions made regarding the decay process or the conditions under which the measurements were taken, which may affect the calculation of the half-life.
Students or individuals interested in nuclear physics, radioisotope decay, and mathematical modeling of radioactive processes may find this discussion relevant.
UWMpanther
[SOLVED] Half Life Help
The activity of a radioisotope is 3000 counts per minute at one time and 2736 counts per minute 48 hours later. What is the half-life of th radioisotope?
This is where I'm completely lost.
See here for some information:
http://hyperphysics.phy-astr.gsu.edu/hbase/nuclear/halfli2.html#c3
http://hyperphysics.phy-astr.gsu.edu/hbase/nuclear/halfli2.html#c2
You first need to figure out the decay constant (represented by [tex]\lambda[/tex]), which you can do by using the decay equation. Once you have that, you can find the half-life*. The equations you need are in the link. Give it a try and see what you come up with.
*Or you could just substitute the expression for lambda (which relates to the half-life) into the decay equation and solve for the half-life all in one go. Same thing.
[tex]\ln{\frac {[A]_{0}}{[A]_{t}}} = kt[/tex]
[tex]t_{\frac {1}{2}} = \frac {\ln{2}}{k}[/tex]
Take 3000 counts as [tex]A_{0}[/tex] and 2736 counts as [tex]A_{t}[/tex]
Also, do you know how the half-life equation is derived? And what connects these 2 equations?
*don't forget to convert your units.
ok so [tex]\ln{\frac {[A]_{0}}{[A]_{t}}} = kt[/tex] is what I'm going to use to calculate k
and then i use [tex]t_{\frac {1}{2}} = \frac {\ln{2}}{k}[/tex] to calculate for [tex]t_{\frac {1}{2}}[/tex]
Did you get an answer?
yeah I got 21661 mins which then I converted to hours and that is 361 hours.
Looks good to me.
