Half-life of radioactive isotopes near 0 K.
DavidZuccaro
Would the observed half-life of a sample of a radioactive isotope (eg. iodine 131) be different from the nominal half-life when it is cooled down to a temperature near absolute zero.
Have there been any experiments conducted to examine this question?
Welcome to PF!
Temperature does not have any effect on radioactive half-life. Remember that temperature is the average atomic motion. Decay is mediated by the weak nuclear force, which has no relation to the movement of the particle.
Fair enough.
So my follow up question is does the half-life of a particular isotope vary in accordance with any other physical property such as electric field - excepting weak nuclear force which you have mentioned.
Electric fields are not strong enough to have an impact - in addition, if the nucleus sees them, it just accelerates. And electric field gradients are even smaller, when applied to the size of a nucleus.
Three ways to influence nuclear transitions:
- Electron capture needs electrons, and depends on the presence of electrons nearby. There, you can alter the speed of the process.
- In a similar way, you could shoot a lot of neutrinos and stimulate proton<->neutron transformation. However, I do not think this would give a measurable effect.
- Pressure similar to the conditions in white dwarfs or neutron stars. This allows to get particles close enough to have a significant influence.
Toponium is a hadron which is the bound state of a valance top quark and a valance antitop quark. Oversimplified presentations often state that top quarks don't form hadrons, because they decay to bottom quarks extremely rapidly after they are created, leaving no time to form a hadron. And, the vast majority of the time, this is true. But, the lifetime of a top quark is only an average lifetime. Sometimes it decays faster and sometimes it decays slower. In the highly improbable case that...
I'm following this paper by Kitaev on SL(2,R) representations and I'm having a problem in the normalization of the continuous eigenfunctions (eqs. (67)-(70)), which satisfy \langle f_s | f_{s'} \rangle = \int_{0}^{1} \frac{2}{(1-u)^2} f_s(u)^* f_{s'}(u) \, du. \tag{67} The singular contribution of the integral arises at the endpoint u=1 of the integral, and in the limit u \to 1, the function f_s(u) takes on the form f_s(u) \approx a_s (1-u)^{1/2 + i s} + a_s^* (1-u)^{1/2 - i s}. \tag{70}...
