Hamiltonian of the Quantum Harmonic Oscillator-Eigenfunction & Eigenvalue
Calcifur
Show that the equation below is an eigenfunction for the Quantum Harmonic Oscillator Hamiltonian and find its corresponding eigenvalue.
u1(q)=A*q*exp((-q^{2})/2)
Ok, so I know that the Quantum Harmonic Oscillator Hamiltonian (H_{QHO}) is :
(H_{QHO})=\frac{1}{2}\hbarω(((-d^2)/(dq^2))+q^2) and I know that:
(H_{QHO})u1(q)=Eu1(q)
but how do I show that it's an eigenfunction? Simply subbing it into the eqn doesn't appear to help.
Many thanks in advance.
It should. Either that or you need to solve the differential equation, which is a much harder task.
Show us what you got when you plugged u1 into the equation.
Ok, so here goes:
HQHO*U1(q)=E*U1(q)
\frac{1}{2}\hbarω(\frac{-d^{2}}{dq^{2}}+q^{2}).A.q exp(\frac{-q^{2}}{2})=E*U1(q)
\frac{A}{2}\hbarω(-\frac{d}{dq}\frac{d}{dq}(q.exp(\frac{-q^{2}}{2}))+(q^{3})exp(\frac{-q^{2}}{2}))=E*U1(q)
which eventually comes to:
(q^{3}+q^{2}-2q-1)exp(\frac{-q^{2}}{2})\frac{A}{2}\hbarω=E*U1(q)
So does this mean that : (q^{3})+q^{2}-2q-1) is the corresponding eigenvalue?
Is my method correct?
Many thanks.
You must have calculated the second derivative incorrectly. You should get
$$u_1''(q) = (q^3-3q)e^{-q^2/q}.$$
Thanks, my mistake. So I now have:
\frac{\hbarω}{2}A.exp(\frac{-q^{2}}{2})(-q^{3}-q^{2}+3q)=E.U_{1}(q).
So is -q^{3}-q^{2}+3q the corresponding eigenvalue? Or can I simplify even further?
Many thanks.
That's still not correct. The eigenvalue is a constant. It can't depend on q.
I think I've figured it out now. Many thanks Vela
