Handymen - info needed for wall repair
  • Thread starter Thread starter fitz_calc
    Wall
The discussion revolves around methods for repairing a damaged wall in an apartment, focusing on various techniques and materials that can be used for wall repair. Participants share their experiences and suggestions regarding the repair process, including filling methods, texture matching, and painting considerations.
  • Some participants suggest using drywall putty and creativity to match the wall's texture after repair.
  • Others propose that cutting out the damaged section and replacing it may be necessary, as simply filling it could lead to a soft surface.
  • One participant recommends carefully prying the damaged area and using wood putty to secure it back in place, followed by a color touch-up with toothpaste.
  • A different approach involves using non-shrinking spackling for small dents, smoothing it with fine sandpaper, and applying matching paint with a tiny roller.
  • There is a discussion about the challenges of matching paint colors, with some noting the variety of shades available and the need for a paint chip for accurate matching.
  • One participant humorously shares an experience of a larger hole created by a pet, indicating that different repair methods may be needed for varying sizes of damage.
Participants express a range of opinions on the best methods for wall repair, with no consensus reached on a single approach. Different techniques and materials are suggested, reflecting varying levels of experience and preferences.
Some suggestions depend on the size of the damage and the specific wall texture, which may not be fully addressed in the discussion. The effectiveness of proposed methods may vary based on individual circumstances and wall conditions.
Individuals looking for practical advice on home repair, particularly those dealing with wall damage, may find the shared experiences and suggestions beneficial.
fitz_calc
So we managed to damage a wall at our apartment:
http://i.imgur.com/gi5b4.jpg
Handymen of the forums, how would you repair?
like this and afterwards some creativity to match the structure again.
Maybe flinging bits of drywall putty off a paintbrush or a plastic spoon will recreate the odd surfacing. But yes, you will likely have to cut out the small square of drywal land replace - simply filling with a putty would leave a soft surface that holds indentations.
It's difficult to see how big the hole is but you might be able to avoid cutting up the wall. I would carefully pry the damaged area so that it's sticking out slightly (take care to avoid popping it out completely). Then you can put some wood putty along the edges, push it back in place and let it harden. After the putty has hardened for a day, you can use some plain-old white toothpaste to touch up the color of the edges where the putty is showing through.
Get a jar of non-shrinking spackling, fill in dent, let dry, smooth flat with a fine sandpaper, a tiny paint roller used for leaving a texture dipped in matching paint, and VOILA!
There is no need for wire patches if it's just a tiny dent like the one shown.
The only time I had to insert a screen into the drywall to repair a hole was when my labrador retriever, AKA "JAWS OF DEATH" decided to eat a hole through the wall large enough to fit her entire hed through. I have been repairing dents and holes for decades, I'm such a nitpicky perfectionist that I have repaired the repairs done by self-professed "professionals". :redface:
I also learned how to do wood restoration of dog chewed furniture, windowsills, baseboards, and door frames. :biggrin:
Do you have any paint to match. That always seems to be the hardest part. There must be at least 27 different shades of white. Home improvement stores can mach paint but you will need to take in a chip about the size of a quarter.
If it's a small wall, you can paint it a different color and have a fancy "accent wall". Back in hippy days, this is how you wound up with hideous flowers and other weird things painted over holes.
Before I got around to the huge labrador hole, I just pulled a bookcase in front of it.
  • · Replies 23 ·
  • · Replies 23 ·
