Optimal Painting Height for Maximum Viewing Comfort | 3m Viewing Distance
  • Thread starter Thread starter acidxc
To determine the optimal height for hanging a painting for maximum viewing comfort at a 3-meter distance, the center of the painting should be positioned so that visitors do not have to look up or down more than 5 degrees. Given the expected eye levels of visitors between 152 cm and 200 cm, a geometric approach using right triangles can be applied. The height difference between the maximum and minimum eye levels is 48 cm, which helps establish the necessary angles. By calculating the height above the shortest viewer's eye level, the center of the painting can be accurately positioned. This ensures a comfortable viewing experience for all visitors.
acidxc
hi,
can someone help me on 1 question i have been really trying and don't seem to know how to do it here is the question;
Francis is hanging a painting on a wall, he wants the height on the center of the painting to be located so that no visiors need to look up or down more the 5 degrees to viwer the center of the painting when standing 3 m away. If he expects visitors eyes to be between 152 cm to 200 cm off the ground. What is the range of heights that he can hang the center of the painting, to the nearest centimeter
So far i have done the following iam not sure if its the right start
x
Your picture is wrong. I presume that the vertical line labeled "200 cm" on the left represents the picture. You are told "no visiors need to look up or down more the 5 degrees to viwer the center of the painting when standing 3 m away" and that "he expects visitors eyes to be between 152 cm to 200 cm off the ground". You should have two lines drawn from the center of the picture to a vertical line 3 m away-one up to a height 200 cm, the other down to a height 152 cm. In other words, you should have a triangle with vertex at the center of the picture, vertical side of length 200- 152= 48 cm and base angles of 5 degrees. If you draw a horizontal line from the lower end of that vertical 48 cm line, representing the eyes of the shortest person, you have a right triangle with angle 5 degrees and near side 3 m= 300 cm. The opposite side is the height above that persons eyes (152 cm) to the center of the picture. Adding 152 to that will give the height of the center of the picture above the floor.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
