Derivator
- 147
Hi folks,
Hartree Fock theory tells us, that the energy functional <\Psi|H|\Psi> where \Psi is a single Slater determinant is minimized by using spin orbitals \phi_i that fulfill the Hartree Fock equations f_i \phi_i = \epsilon_i \phi_i.
Since the Fock operator f_i depends on the solution, the hartree fock equations are solved in a self consistent iteration. That is, for an N-particle Slater determinant, one starts with N guessed spin-orbitals, uses these guessed spin orbitals to calculate the fock operator, then one solves the eigenvalue problem given by this guessed fock operator, obtains new spin orbitals, calculates a new fock operator and so on... until there is no difference between input and output spin orbitals.
My question:
Suppose, you have guessed N spin-orbitals and have obtained an initial fock operator \tilde f_i. Then you want to solve the eigen-problem \tilde f_i \phi_i = \epsilon_i \phi_i to obtain N new spin orbitals \phi_i. However solving \tilde f_i \phi_i = \epsilon_i \phi_i will give you an infinite number of spin orbitals. Which of them will you use to construct your new fock matrix?
best,
derivator
My question:
best,
derivator
