Having trouble with a fairly simple integration
  • Thread starter Thread starter Pandabasher
    Integration
The discussion revolves around solving a differential equation using integration factors, specifically focusing on the integral \(\int \frac {e^{\frac {-1}{x}}}{x^4} dx\). Participants are exploring various methods of integration, particularly integration by parts and substitutions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants suggest different approaches to tackle the integral, including splitting the integral into parts and using substitutions. There are questions about the effectiveness of these methods and requests for clarification on specific difficulties encountered during the integration process.
Some participants have provided guidance on potential substitutions and integration techniques. There is an ongoing exploration of the problem, with no explicit consensus reached on the best approach. One participant has confirmed their result using an external tool, while others encourage checking work through differentiation.
Participants are discussing the importance of including the integration constant in their final answers to represent the family of antiderivatives. There is an acknowledgment of the challenges faced with integration techniques among some participants.
Pandabasher
I'm in the middle of solving a D.E using integration factors, and I've ended up with an integral on the R.H.S which is as follows: [tex]\displaystyle \int \frac {e^ \frac {-1}{x}}{x^4} dx[/tex]
I've tried to use integration by parts to do it, but I keep having to use it again and again. I've checked that my integrating factor is correct, and it is. I'm just having a hard time doing it. Any help is greatly appreciated. Thanks, Matt.
Try splitting it this way:
u = x^(-2), dv = x^(-2)e^(-1/x)dx
I haven't worked it through, so can't guarantee this will work, but this is what I would try.
Okay, thanks. I'll give it a go.
If you let 1/x = t (new variable), what do you get ?
I would start by substituting u=(-1/x). The integration by parts should be straightforward. You only need to do it twice. Can you show where you are having problems?
Using [tex]\displaystyle u= \frac {-1}{x}[/tex] I get [tex]\displaystyle \int e^{u} u^{2} du[/tex]
Then I used integration by parts to get that equal to [tex]\displaystyle u^{2}e^{u} - \int 2u e^{u} du[/tex]
Then using integration by parts again I get that equal to [tex]\displaystyle 2u e^{u} - \int 2e^{u}[/tex] which is just [tex]\displaystyle 2u e^{u} - 2e^{u}[/tex]
Then subbing back in and taking out a factor of [tex]\displaystyle e^u[/tex] I get the answer to the first integral as [tex]\displaystyle e^{u}(u^{2}-2u+2)[/tex]
And subbing u back in I get [tex]\displaystyle e^{ \frac {-1}{x}}( { \frac {1}{x^{2}}} + { \frac {2}{x}} + 2)[/tex]
Does that look right?
You can check yourself - differentiate what you ended with and you should get the integrand of your integral.
Yeah I checked it with wolfram, its correct. Thanks for the tip, I'm not that good with integrals so I probably wouldn't have spotted that.
Late I am, but for the record, don't leave out the integration constant, because it shows what you're looking for: the 'family' of antiderivatives.
  • · Replies 22 ·
