What Are Some Substitutions That Can Be Used to Solve This Integral?
  • Thread starter Thread starter baldbrain
    Integals Integral
The integral I = ∫√((cosx - cos^3x)/(1 - cos^3x)) dx can be simplified using the substitution cosx = t, leading to I = ∫-√(t/(1 - t^3)) dt. The discussion highlights that the integrand does not exist as a real number in the interval [π/2, 3π/2] + 2nπ, but notes that a function's discontinuity does not necessarily imply its anti-derivative is also discontinuous. A successful substitution t = sin^(2/3)s allows for further simplification, resulting in I = (-2/3)sin^(-1)(cos^(3/2)x) + c. An alternative substitution, √(1 - cos^3x) = t, also provides a valid solution, yielding I = (2/3)sin^(-1)(√(1 - cos^3x)) + c.
baldbrain
Evaluate $$\int{\sqrt{\frac{cosx - cos^3x} {1-cos^3x}}}\,dx$$
All the basic Integration formulae
Let I = ##\int{\sqrt{\frac{cosx - cos^3x} {1-cos^3x}}}\,dx##
I = ##\int{\sqrt{\frac{cosx(1 - cos^2x)} {1 - cos^3x}}}\,dx##
I = ##\int{\sqrt{\frac {cosx} {1 - cos^3x }}}sinx\,dx##
Substitute ##cosx = t##
Therefore, ##sinx\,dx = -dt##
So, I = ##\int{-\sqrt{\frac {t} {1 - t^3}}}\,dt##
I'm stuck here...
the integrand does not exist as a real number in ##\left [\pi/2, 3\pi/2\right ] + 2n\pi##
Try the substitution ##t=\sin^{2/3}s##.
My book says if a function is discontinuous (or doesn't exist) at a point, it's not necessary that it's anti-derivative is also discontinuous ( or doesn't exist) at that point. They've given the example of
$$\int x^{-1/3}\,dx$$ Even though the function doesn't exist at x = 0, it's anti-derivative ##\frac {x^{2/3}} {2/3} + c## is continuous at x = 0
Yes, that seems to do it. :smile:
##dt=(\frac{-2}{3})(\sin^{-1/3}s)(\cos{s})ds##. Also, ##\sqrt{t} = sin^{1/3}s## & ##\sqrt{1 - t^3} = cos s##
Hence, I = ##\int{\frac{-2}{3}\frac{(sin^{1/3}s)(coss)} {(coss)(sin^{1/3}s)}}\,ds##
I = ##\int{\frac{-2}{3}}\,ds## = ##\frac{-2}{3}s + c##
I = ##\frac{-2}{3}\sin^{-1}{(cos^{3/2}x)} + c##
Thanks
Alternatively, the substitution ##\sqrt{1-cos^3x} = t## also works.
That yields
I = ##\frac{2}{3}\sin^{-1}{(\sqrt{1-cos^3x})} + c##
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
  • · Replies 22 ·
