Optimizing Heat Transfer in Boiler Tubes: Tube Number & Length Calculations
The forum discussion focuses on optimizing heat transfer in boiler tubes, specifically calculating the number of tubes and their lengths based on given parameters. The calculations indicate that at a flue gas velocity of 22 m/s, a minimum of 1160 tubes is required, while at 28 m/s, 912 tubes are necessary. The overall lengths of the tubes are calculated to be approximately 1.005 m and 1.279 m, respectively. Additionally, it is determined that at least three passes are required for both scenarios to keep the tube length under 5 meters.
  • Understanding of fluid dynamics principles, particularly in heat transfer.
  • Familiarity with boiler design and tube specifications.
  • Proficiency in using equations related to heat transfer area and flow rates.
  • Knowledge of unit conversions and dimensional analysis in engineering contexts.
  • Research "Boiler tube design calculations" for further insights into tube configurations.
  • Explore "Heat exchanger performance optimization" techniques to enhance efficiency.
  • Learn about "Fluid dynamics in thermal systems" to deepen understanding of flow behavior.
  • Investigate "Pressure drop calculations in piping systems" to evaluate system performance.
Engineers, thermal system designers, and students studying mechanical engineering who are involved in boiler design and optimization of heat transfer processes.
Andy86
flue gases = 50,000kg h^-1
surface area = 113.57m^2
Do = 25 + (3*2) = 31mm
The tubes within a boiler are 25mm inside diameter with a wall thickness of 3mm. The flue gas velocity through the tubes is to maintain the overall heat transfer coefficient value and minimise pressure losses to be more than 22ms^-1 and less than 28ms^-1
Assuming average density of the flue gases is 1.108kgm^-3
(i) calculate the minimum and maximum number of tubes in each pass
(ii) overall length of tubes at each of these numbers of tubes
(iii) the minimum number of tube passes in each case if the boiler tube is to be less than 5M
number of tubes = (4 * qmc(s)) / (density * π * Di * V)
A= π * Do * L * N
L = A / π * Do * N
A= π * D * L * N
rearranged
N= (A/L) / (π*Do)
[/B]
(i)
qmc= 50,000/3600
=13.88kg s^-1
minimum velocity @ 22ms^1
= (4 x 13.88) / (1.108 * π * (25*10^-3)*22)
=1160 tubes
minimum velocity @ 28ms^1
= (4 x 13.88) / (1.108 * π * (25*10^-3)*28)
=912 tubes
(ii)
A= π * Do * L * N
rearranged
L = A / π * Do * N
1160 tubes
L = 113.57 / π * (31*10^-3) * 1160
L= 1.005M
912 tubes
L = 113.57 / π * (31*10^-3) * 912
L= 1.279M
(iii) COMPLETELY LOST! been barking up the following tree but can't make it work! some help would be greatly appreciated!
calculate number of tubes required in each case based on a tube length of 5M
A= π * D * L * N
rearranged
N= (A/L) / (π*Do)
22 ms^-1
=(113.57/5)/(π*(31*10^-3)
= 233.2
= 234 tubes @ 5m
26 ms^-1
= 233.2
= 234 tubes @ 5m
I was thinking of working out the area for that number of tubes (in each case) ie 912 and 1160 based on the tube lengths calculated in (ii) then plugging the new area into (iii) using L=5m and leaving N as the variable?? SOS
It looks like only one pass is required. There must be something wrong with the problem statement.
Andy86 said:
http://imgur.com/a/D5qqN
That is the original question paper ^^^
My calculated heat transfer area doesn't match yours.
I have just checked it. I got ;
heat transfer duty = qmH * Hfg
= (3598.5 * 2015) / 3600
= 2014.1KW
Area m^2 = heat transfer duty / U * LMTD
= (2014.1*10^3) / (54 * 328.4)
= 113.57m^2
Heat load = (50000/3600)(1150)(1600-200)=22,400,000 W
Im not entirely sure where that calc comes from (im not doubting it BTW), if that was the case the area would be;
= (22400*10^3) / (54 * 328.4)
= 1263.1m^2
seems a bit excessive but I could be wrong?
That's the rate of heat loss from the flue gas, which gets transferred to the liquid water to make steam.
ok, so if you follow it through what surface area do you get?
I get the value you got.
ok great, so if you follow the question through to where I was struggling;
Do you have any thoughts on how to tackle this?
The total area is ##\pi D L n##, where n is the number of tubes and L is the length of each tube. So, first find the length of each tube. The tube bank has to fit into a space no longer than 5 meters. If L is greater than 5 meters, you need to "fold" the tubes once or more so that there are enough tube passes to accommodate the total tube length within the allowable space.
Ok great, ill have a look in the morning its very late here now (UK), thanks for your help Chester! Hopefully I will have some sensible answers tomorrow!
3ci)
Di = 25mm
D0= 31mm
Min V = 22ms^-1
Max V= 28ms^-1
qMc = 50000/3600
Heat load = 50000/3600 * 1150 * (1600-200)
=24000
Area = 22400*10^3 / (54*328.4)
= 1263.1M^2
Min number of tubes in each
22 ms^-1
N = 4*13.88 / 1.108 * π * (25*10^-3)^2 * 22
N = 1160 Tubes @ 22 m s ^-1
28 ms^-1
N = 4*13.88 / 1.108 * π * (25*10^-3)^2 * 28
N = 912 Tubes @ 22 m s ^-1
3cii) Overall length of tubes in each case
A = π * D * L * N
Re arranged
L = A / π * D * N
= 1263 / π * (31*10^-3) * 1160
= 11.18M @ 1160 Tubes
L = A / π * D * N
= 1263 / π * (31*10^-3) * 912
= 14.22M @ 1160 Tubes
3ciii) Minimum number of passes in each case
V = 22 ms^-1
L = 11.18M @ 1160
= 11.18 / 5
= 2.236 > 3 Passes required
V = 28 ms^-1
L = 14.22M @ 912
= 14.22 / 5
= 2.844 > 3 Passes required
Hopefully this is somewhere near!?
  • · Replies 50 ·
12K
  • · Replies 19 ·
  • · Replies 104 ·
12K
  • · Replies 25 ·
