Heat propagation in radiating surface
Heat propagation in a material exposed to sunlight in a vacuum can be analyzed using the Stefan-Boltzmann law, which governs radiation absorption and emission. For a one-dimensional material with one end illuminated and the other insulated, the challenge lies in calculating the heat flow without fixed temperature boundaries or convection. Approximations such as Fourier analysis may be useful, particularly when the material thickness is comparable to the wavelength of sunlight. Understanding the angle of emission and the surrounding temperature is crucial for accurate calculations. Resources on sunlight's effect on Earth may provide insights into applying these principles.
Jairo Amaral
I would like to know how heat would flow in a material being struck by sunlight in vacuum. The usual examples of Fourier heat equation always uses boundaries with fixed temperature or under convection. How do I calculate this when the surface is absorbing and emitting radiation according to Stephan-Boltzmann law?
I'm considering a 1-dimensional material in vacuum, with one ending being lit, and the other being insulated. Is the analytical solution too hard to be pratically solved? If yes, do you know some source for computing this numerically? If no, do you know some source that shows this solution?
This problem seems simple, but I've tried internet, teachers and books for some days, and I've still found nothing.
Thanks.
Science news on Phys.org
A great question. What first comes to mind is that for a material of thickness d>>lambdasunlight and relatively finite time, the heat of sunlight (for ultraviolet or infrared divergence) may not need strict representation in an eigenvalue problem, and gives a constant specific heat in this visual range. If d~lambdasunlight, then I would try an approximation technique, like using Fourier analysis on either the Raleigh-Jeans approximation or a form of Wien's law.
Sorry if I made the problem too complicated. It should be easier. I'll try to figure it out.
Jairo Amaral:
It seems simple.
I think the problem is knowing how the radiated power is distributed in function of the angle of emission. I don't know the answer.
And you have to know the temperature of the "universe" ( where there is no sun ).
And you have to know the shape of the material.
Once you know all this, just make a big integral.
If the material is very near to the sun ( the material sees the sun at all angles ) the temperature will be the same.
Jairo,
q=-k grad (T)=-k grad (W/s)1/4
where q is the heat flux per unit time, k is the thermal conductivity, T is temperature, W is the radiant emittance of a blackbody, and the Stefan-Boltzmann constant s=5.67 x 10-12 watts cm-2 deg-4.
It's a start. You may want to consider this for a unit area and flat surface (your one dimensional simplification).
The internet has examples of "sunlight striking Earth" using the "Stefan-Boltzmann law" and the "Heat Equation" or similar combinations of terms.
Again, please forgive my poor attempt.
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
11K
