Heat transfer and Fluid Flow Struggling Problems
25 replies · 5K views
williamcarter
Hello, I am struggling with this heat transfer and fluid flow problem.I would really appreciate if someone could have a look over what I have done on it.
I am not sure if what I have done is correct ,I would really appreciate if you could tell me if it is correct or wrong.And also I would really appreciate if you could correct what I did wrong.
Thank you in advance.
Question 2) image: http://imgur.com/aJCzNyB
Question 3) image http://imgur.com/wFl93SA
Table image: http://i.stack.imgur.com/aiO1J.jpg
Q2.Data:
a)[/B]
layer of snow=x=20*10^-2 m
thermal conductivity(lambda)=0.3W/m*K
Tair(inside)=18 Degrees Celsius
Tinterface=0 Degrees Celsius
Roof area=9m^2
Polycarbonate sheet x'=25*10^-3 m
latent heat of ice=333.5 kj/kg
b)
A=100cm^2
Pin=100KPa
Pout=60KPa
u=15m/s
Q3 Data.
a)
L=30m
D=6*10^(-2)m
composite material x=2*10^(-2)m
lambda(thermal conduct)=0.4W/m*k
Ti (inside temp of insulation)=130 degrees celsius
Tair=10 degrees celsius
h=20W/m^2*k(convective heat transfer coefficient)
b)
D=10^-3m
Specific gravity=0.8=>Petrol ro(density)=800kg/m^3
Pvap=60KPa abs=>Pvap=101.3-60=41.3KPa gauge
Q2 Solved
i)[/B]Q=delta T/Rtotal
delta T=(18-0)
Rtotal=1/UA=(1/hi+xsnow/lambda snow)*1/A=(1/25+0.2/03)*1/9=0.07851
=>Q=(18-0)/0.07851
=>Q=229.24W
ii)Q=? if ice melts at 1.8 kg/h
m=1.8kg/h=1.8kg/3600s=5*10^-4 kg/s
Q=m*hmelting (phase change)
Q=5*10^-4*333.5
Q=0.16675 Kw
iii)h=6W/m^2*k (convective heat transfer coefficient)
Toutside air=?
We know Qconv=hA*delta T or q=h*Delta T
Struggle on this one.
I stopped here , I am confused how to solve this one.
b)U bend pipe, force to keep in place
A=ct=100cm^2=0.01m^2
Pin=100Kpa
Pout=60Kpa
u=15m/s
F=?to hold pipe in place
Fm(momentum force)=m*u=ro*q*u=ro*A*u^2
Fmx=m*u=m*(u2-u1) if done on fluid
Fmx=m*u=m*(u1-u2) if done by fluid
Fmx=ro*A*u^2=10^3*0.01*15^2
Fmx=2250N(in X direction)
Fmy= - 2250N n(in Y direction)
Fpx=P1A1-P2A2
FPx=10^5Pa*10^-2 m^2
FPx=10^3 N(in X direction)
Fpy=-10^3 N(in Y direction)
Fx=Fmx+FPx=3250N
Fy=Fmy+Fpy=-3250N
Magnitude of force =sqrt(Fx^2+Fy^2)=sqrt(3250^2+3250^2)=4956N
Force to keep pipe in place=reaction force equal in magnitude but opposite in direction
=> Force to keep pipe in place Fr= -4956 N
Q3.solved
a)i)
q(heat flux)=?
q=U*delta T
1/U=1/h+x/lambda
=>1/U=1/20+2*10^-2/0.4=>1/U=0.1=>U=10
q=U*delta T=10*(130-10)
q=1200 W/m^2*k
ii)if x'=2*x
=>q'=U' *delta T
1/U'=1/h+2x/lambda=1/20+4*10^-2/0.4=>U=6.6
=>q=800W/m^2
iii)increasing insulation layer is also increasing safety level by reducing q(heat flux)
b)
Vol=2L Petrol=2*10^-3 m^3
D=10^-3m
=>A=7.85*10^-5 m^2
Pvap=60KPa abs
We apply Bernoulli equation P1/ro*g+h1+u1^2/2*g=P2/ro*g+h2+u2^2/2*g
Taking points 1 and 2 as below
http://imgur.com/cDR2v51
Point 1 on the bottom of the tank
Point 2 discharged in atmosphere from siphon
time t=Volume/Volumetric flowrate
for point 1:
u1=0(we can neglect velocity due to difference in Area between point1 and 2)
h1=1m
P1=41.3*10^3Pa
for point2:
u2=?we will find it
P2=0(due to atmosphere)
h2=0(datum point)
Plug all those values in main Bernoulli equation
=> u2^2=(P1/ro*g+h1)*2g
u2=sqrt( (P1/ro*g +h1)*2g
u2=sqrt( (41.3*10^3/800*9.81+1)*2*9.81
=>u2=11.08 m/s
we know q(volumetric flowrate)= u*A
=>q=u2*A2(area of siphon)
q=11.08 m/s*7.85*10^-5 m^2
q=8.70*10^-4 m^3/s
but time t=V/q
t=2*10^-3 m^3/8.70*10^-4 m^3/s
=>time=2.29 seconds
ii) find maximum allowable h in order to maintain flow.
I struggle here.
Q2.Data:
a)[/B]
Roof area=9m^2
b)
A=100cm^2
Pin=100KPa
Pout=60KPa
u=15m/s
Q3 Data.
a)
L=30m
D=6*10^(-2)m
b)
D=10^-3m
Q2 Solved
delta T=(18-0)
=>Q=(18-0)/0.07851
=>Q=229.24W
Q=5*10^-4*333.5
Q=0.16675 Kw
Toutside air=?
You showed that the heat flow through the roof layer is 229 W and that 167 W of this is used to bring about the phase change at the interface between the snow and the roof. So you are left with 62 W for the rate of heat flow from 0 C at the snow interface with the roof to the outside air. What outside air temperature is required to drive this heat flow?
Pin=100Kpa
Pout=60Kpa
u=15m/s
Fpx=P1A1-P2A2
Fx=Fmx+FPx=3250N
Fy=Fmy+Fpy=-3250N
You kinda had the right idea here, but not quite. If you regard the total pipe bend as your control volume, there is no component of force in the y direction. For the x direction, if F is the force exerted by the bend on the fluid in the negative x direction, then $$P_{in}A-P_{out}A-F=-2\rho A v^2$$ where the right hand side is the rate of change in fluid momentum in the positive x direction.
Q3.solved
a)i)
q(heat flux)=?
q=U*delta T
1/U=1/h+x/lambda
q=1200 W/m^2*k
ii)if x'=2*x
=>q'=U' *delta T
=>q=800W/m^2
This problem is not done correctly because you haven't taken into account the cylindrical geometry. Within the insulation, the heat conduction equation should be $$q=-k\frac{dT}{dr}$$, and the heat balance equation should be $$\frac{d(qr)}{dr}=0$$ or equivalently$$qr=const$$ These equations need to be solved simultaneously to get the temperature profile and the heat flux. Then, this solution has to be properly merged with the convective heat transfer.
In part iii, you should be comparing the ratio of the conductive resistance to the convective resistance.
b)
D=10^-3m
=>A=7.85*10^-5 m^2
Pvap=60KPa abs
for point 1:
h1=1m
P1=41.3*10^3Pa
for point2:
u2=?we will find it
h2=0(datum point)
=>u2=11.08 m/s
q=8.70*10^-4 m^3/s
but time t=V/q
=>time=2.29 seconds
I struggle here.
Bernoulli's equation is not applied correctly here. The vapor pressure of Petrol has nothing to do with the pressure at point 1. The pressure at point 1 is determined from the hydrostatic equation within the tank. Or you could apply the Bernoulli equation to the combination of a point at the very top of the tank (where the pressure is atmospheric) and point 2, where the pressure is again atmospheric. Either way, you will get the same answer.
To answer part ii, you need to consider the absolute pressure at location h (at the top of the siphon) and compare this with the vapor pressure of the Petrol. If the pressure at this location is calculated to be less than the vapor pressure of the petrol, you will get cavitation (and the siphon will not work).
Please, in the future, submit problems is separate threads. You have actually submitted 4 problems within this thread. This is not acceptable.
for Question2) iii)
I did delta Q=Q1-Q2
where Q1=229.2 W from above subpoints of exercise
Q2=166.75 W rate of heat transfer to melt ice
=> delta Q=62.49 W
Q=h*A*delta T(convection) => delta T=Q/h*A =>(Tsnow-Toutside)=Q/hA
=>To=Tsnow-Q/hA
To=0-62.49/6*9
To(outside air temp)= - 1.15 degrees Celsius
for Question2 b) U-bend pipe
F=force to keep pipe in place=Fm(momentum force)+Fp(pressure force)
Fm=ro*A*u^2=10^3*10^-2*15^2=2250N
Fp=P1A1-P2A2=(10^5Pa*10^-2)-(6*10^4Pa*10^-2)
Fp=400N
=>F=Fm+Fp
F=2250+400
F=2650 N( force to keep pipe in place)
For question 3)
i) I tried using Laplace equation and by integrating and putting boundary conditions I got:
Temp profile T(x)=(T2-T1)*x/L+T1
=>T(x)=(10-130)*2*10^-2/30 +130
T(x)=129.92
q(x)=-lambda/L *(T2-T1)
q(x)= -0.4/30 *(10-130)
q(x)=1.6 W/m^2 (heat flux)
Now I do not know how to connect this to heat flux from convection q=h*delta T
For question 3b)
I do not know how to apply hydrostatic pressure
for point 1(let's say is on the bottom of the tank) P1=ro*g*h1=800*9.81*1m=7848Pa ,if at point 2 h2=0(datum)
However for point 3 let's say somewhere in fluid above, at 4m P3=ro*g*h3=800*9.81*4m
P3=31392 Pa, which is incorrect because the deeper we go , the pressure should be bigger but in this case is opposite.
I applied Bernoulli as above but I took the point 1 as at the top of the fluid of the tank.
So for point 1: u1=0,P1=0, h1=4m;
For point 2:u2=? P1=0; h2=0m(datum)
=> u2=sqrt(2*g*h1)
u2=sqrt(2*9.81*4)
u2=8.86 m/s
Area of siphon=pi*D^2/4=pi*(10^-2)^2/4
Asiphon=7.85*10^-5 m^2
q=u2*Asiphon=8.86m/s*7.85*10^-5 m^2
q=6.95*10^-4 m^3/s
t(time)=V/q=2*10^-3 m^3/ 6.95*10^-4 m^3/s
t=2.87 seconds
For question 3 last part with maximum height
I will calculate the hydrostatic Pressure in point 3 which is at top of siphon
P=ro*g*h for Gauge Pressure
P=Patm+ro*g*h to make Absolute Pressure
=>P3=Patm + ro*g*h3=800 kg/m^3 *9.81 m/s^2 *4m
P3=31392 Pa gauge
P3=69933Pa=69.9 Kpa absolute > 60KPa vap absolute
We apply again Bernoulli eq:
for point 3: P3=31392 Pa gauge ; u3=0;h3=?
for point 2: P2=0 ; u2=8.86 m/s (from above) h2=0;
h3=u2^2/2*g -P3/ro*g
h3=8.86^2/2*9.81 - 31392 /800*9.81
h3=9.98*10^ -4 meters
williamcarter said:
for Question2) iii)
I did delta Q=Q1-Q2
=> delta Q=62.49 W
=>To=Tsnow-Q/hA
To=0-62.49/6*9
You omitted the (conductive) temperature difference across the layer of snow.
Fp=400N
=>F=Fm+Fp
F=2250+400
I didn't check this result. Is it consistent with the equation I gave for the force exerted by the bend on the fluid in my previous post?
For question 3)
T(x)=129.92
You need to use the Laplace equation in cylindrical coordinates. Using the equation in cartesian coordinates is not correct.
The two resistances are in series. $$(\Delta T)_A=\frac{Q}{R_A}$$$$(\Delta T)_B=\frac{Q}{R_B}$$
$$(\Delta T)_{total}=(\Delta T)_A+(\Delta T)_B=\frac{Q}{R_A}+\frac{Q}{R_B}$$
Then solve for Q.
For question 3b)
I don't understand what you did here.
=> u2=sqrt(2*g*h1)
u2=sqrt(2*9.81*4)
u2=8.86 m/s
q=6.95*10^-4 m^3/s
t=2.87 seconds
This is correct.
This equation should have a minus sign.
This equation should also have a minus sign:
P=Patm-ro*g*h=100 kPa-ro*g*h
In order to avoid cavitation, this pressure must be greater than the equilibrium vapor pressure of the liquid.
EDIT: Actually, after further consideration, I realize that I left out a term in the equation for the pressure at the top of the bend. The correct application of the Bernoulli equation should be:
$$P+\rho g h+\rho \frac{v^2}{2}=P_{atm}$$
Therefore, $$P=P_{atm}-\rho g h-\rho \frac{v^2}{2}$$
What exactly do you mean that I omitted conductive temp difference, and where exactly am I supposed to add that?
There is a resistance to heat transfer through the layer of snow.
Thank you for quick reply, but where am I supposed to plug in that temp difference of conduction?
$$\frac{62.49}{9}=0.3\frac{(0-T)}{0.2}$$where T is the temperature at the outer surface of the snow.
q=−kdTdrq=−kdTdr​
q=-k\frac{dT}{dr}, and the heat balance equation should be
d(qr)dr=0d(qr)dr=0​
\frac{d(qr)}{dr}=0 or equivalently
qr=constqr=const​
qr=const These equations need to be solved simultaneously to get the temperature profile and the heat flux. Then, this solution has to be properly merged with the convective heat transfer.
I know the first one is from Fourier for conduction
I would really appreciate it if you could give me some more hints, I am stuck on this one.
I knew that d/dr*(r*dT/dr)=0
If Q is the total rate of heat flow through the insulation (in W), for a cylindrical surface of length L and arbitrary radial location r within the insulation, what is the heat flux at this radial location (in terms of Q, L, and r, but not T)?
Q=q*A
Q=q*2pi*r*L
=>q=Q/2*pi*r*L
williamcarter said:
Q=q*A
Q=q*2pi*r*L
=>q=Q/2*pi*r*L
Good. Now, in terms of the thermal conductivity k and the temperature gradient dT/dr, what is the heat flux q?
Thank you for your answer.
q= -k*dT/dr from Fourier's law of conduction
You need to learn how to use LaTex. Look under INFO drop down menu and click on Help/How to, then click on LaTex Primer.
Good. Now set them equal. What do you get?
##Q=-k* \frac {dT} {dr} *2\pi*r*L##
Good. Now solve the ordinary linear differential equation for T as a function of r, subject to the boundary condition that ##T=T_i## at the inner boundary of the insulation, ##r=r_i##. (I feel like we've gone through all of this before).
##T(r)=-\frac Q {k*2*\pi*L}* ln|r|+c1##
What happened to substituting the boundary condition?
I didn't totally understood that part, what exactly to do with that.
Determine the constant of integration c1 (algebraically) using the boundary condition, and substitute that back into the equation.
##c1=T(r)+\frac {Q} {2*\pi*k*L}##
Like this ?and now plug in values for r=ri and T=Ti
where ##Ti=130 degrees Celsius## and ri=2*10-2
and ##L=30m## and ##lambda=0.4 W/m*K##
Algebraically, please.
I did not quite understood what exactly needs to be done here algebrically with the boundary conditions , could you please lend me a hand? I don't know what I am doing wrong on it.
$$T(r)=-\frac {Q}{2k\pi L}\ln{r}+c1$$
$$c_1=T(r_i)+\frac {Q}{2k\pi L}\ln{r_i}$$where ##r_i## is the radius at the inner surface of the insulation, and ##T(r_i)## is the temperature at that location.
$$T(r)=T(r_i)-\frac {Q}{2k\pi L}\ln(r/r_i)$$
From this equation, what is the temperature ##T(r_0)## at the outer surface of the insulation ##r_0##?
