How Does Heat Transfer Affect Engine Block Surface Temperatures?
The discussion focuses on calculating the surface temperature of a cast iron engine block with a thickness of 1/2" and an internal temperature of 260°F. The cast iron acts as an insulator, resulting in a lower outer surface temperature, which can be approximated using thermal resistance principles. The temperature difference across the material depends on the heat flow and the thermal conductivity of cast iron. The heat transfer is influenced by the rate of new cold air arriving at the block's surface, as this affects the convective heat transfer. Ultimately, the outer surface temperature is estimated to be around 259°F.
kosl
This is the scenario..
I have a engine and the block is made of cast iron which is 1/2" thick.
The internal temperature of the engine within the cooling passages is 260° F
Is there a way to calculate an approximate surface temperature on the outside of the engine block? If so, what would the temperature be?
Say that there was another cooling passage on the other side.. if the passage behind the 1/2" of iron was 260°, what would be the second cooling passages temperature?
Science news on Phys.org
So let me get this straight, as I'm not familiar with engine terms
you want the surface temperature of the 1/2 cast iron, and the air temperature a certain point above this surface?
No, not really. The cast iron will act as a insulator, so the surfice teperature on the outside of the block will be less than on the inside of the block. I'm just wanting to know how much less.
This is a thermal resistance question.
The temperature difference depends on the thermal resistance of the material and the heat flow. You can look up the temperature difference across a given thickness of cast iron for a given heat flow.
The complication comes when the temperature of the material on the other side isn't controlled. Suppose you want to know the temperature of air above the engine block.
Initially it is cold and you have a certain temperature difference across the cast iron, you can then work out the heat flow. But this heat flow will heat the air and so reduce the temperature difference, which will reduce the heat flow. Eventually the air is the same temperature as the inside of the engine then there is no temperature difference and so no heat flow.
Becuase of this, the most important factor is the rate of new cold air arriving at the outside of the engine.
This is a combined heat transfer problem i.e. heat is conducted through the engine block and convected off the block by natural convection. It requires several simplifying assumptions such as:
* The engine block is modled as a horizontal plat with heated surface facing up
*The ambient room temperature is 80 degrees F
*You can neglect radiant heat transfer
q-conduction=q-convection
q-conduction= k*A/L(260-Ts)
q-convection= ho*A(Ts-80)
ho is the convective heat transfer coef (about 1.215 Btu/(hr*ft^2*F) for this problem) requires formulas for natural convection available in any Heat transfer text
k is thermal conductivity for cast iron
L is cast iron thickness in ft
Given the thin engine block wall and high conductivity of cast iron the outer surface of the engine block will be about 259 F
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
