Calculating Temperature Change in a Heat Transfer System
  • Thread starter Thread starter science.girl
    Heat Heat transfer
The discussion focuses on calculating the temperature change in a heat transfer system involving a metal piece and a liquid. The metal, with a mass of 1.50 kg and specific heat of 200 J/kg·°C, is initially at 100°C and is dropped into a liquid of mass 3.00 kg and specific heat of 1,000 J/kg·°C, initially at 0°C. After 5 seconds, the metal's temperature drops to 20°C, prompting the need to determine the final temperature of the liquid using the equation Q = mcΔT, where heat absorbed equals heat released. Participants emphasize the importance of applying the first law of thermodynamics to visualize the problem effectively.
  • Understanding of specific heat capacity and its formula Q = mcΔT
  • Familiarity with the first law of thermodynamics
  • Basic knowledge of heat transfer principles
  • Ability to manipulate algebraic equations for solving physics problems
  • Study the first law of thermodynamics in detail
  • Learn how to apply the specific heat formula in various scenarios
  • Explore examples of heat transfer problems involving multiple substances
  • Investigate the steady flow energy equation for more complex thermodynamic systems
Students studying physics, particularly those focusing on thermodynamics, as well as educators and anyone interested in understanding heat transfer calculations in practical applications.
science.girl
A piece of metal with a mass of 1.50 kg, specific heat of 200 J/kg*oC, and initial temperature of 100oC is dropped into an insulated jar that contains liquid with a mass of 3.00 kg, specific heat of 1,000 J/kg*oC, and initial temperature of 0oC. The piece of metal is removed after 5 seconds, at which time its temperature is 20oC. Neglect any effects of heat transfer to the air or insulated jar.
The temperature of the liquid after the metal is removed is ... ?
[delta]U = Q + W
I'm not sure how to apply an equation to solve this. Any guidance?
The options for the temperature of the liquid after the metal is removed is:
0oC
4oC
8oC
10oC
20oC
science.girl said:
[delta]U = Q + W
Hello science.girl,
Hmmm, that equation you wrote doesn't seem to apply here.
Do you have your physics textbook or class notes handy? You're looking for an equation that contains the specific heat, mass, and temperature change in it -- often denoted by c, m, and ΔT, respectively.
Redbelly98 said:
Hello science.girl,
The only equation I can think of is
c = Q/(m[Tf - Ti])
But, I'm not given a value Q. I would be looking for Tf, right?
Any help? Is there an equation that I'm missing?
Q=mc*(change in temperature)
Where: Q absorbed = Q released
So you can set a side equal to each part of the equation then plug in...
m*c*(Tf-Ti) for the liquid = m*c(Tf-Ti) for the metal
Now I see how the equation is applied. Thank you so much for your help. :smile:
no prob :biggrin:
Also before you do any problem in thermo like this use the 1st law and reduce it down, its good practise to start doing this as it helps to visualise the problem. These are relatively simple but if you ever do anything with the steady flow energy equation you'll see why doing this is useful.
so in this case you take
dU = dQ + qW
we know there is no work, but there is heat transfer.
dU = dQ
This means that the heat flow from the bar into the liquid is the only thing to affect the internal energy. so this means we can apply the Q=mcdt as above.
dU = dQ + qW
dU = dQ
Interesting. This is very useful, Chris. Thank you for this explanation... I will try to apply it to my further studies of physics! :smile:
  • · Replies 16 ·
10K
