Heated water in closed cylinder with electricity
In a closed cylinder filled with water and possibly salt, applying electricity through an anode and cathode will heat the water due to resistance, leading to changes in temperature and pressure. The relationship between pressure and temperature can be described by the equation p1/T1 = p2/T2, indicating that both will rise as energy is added. The discussion raises questions about whether the water will remain liquid or vaporize under these conditions, especially if a valve is opened, potentially causing a rapid release of pressure and a significant acceleration of the cylinder. The complexities of the scenario involve principles from mechanics, electrodynamics, and thermodynamics. Understanding the behavior of water in this context requires consulting steam tables to correlate pressure and temperature accurately.
Joans
Hey, I guess I came to right sub-topic, since I knew here I may have not noticed every thing..
One sleepless night I was thinking about what would happen IF:
in a closed isolated cylinder would be alomost full of H20(+some salt if required).
anode and catode in sides, so what electricity would flow, (it's just a matter of engineering)
electricyti because of resistance would heat the water in amount of time given energy: UIt
so size allways is the same p1/T1=p2/T2 right?
But will water temperature and preasure would conitnue rising ? How?
And would it stay liquid or vapourize?
and for example in a bottom would be a valve or something what would open, and then because of running away preasure a cylinder would fly? :) In fact I tried to use example count and found that accelaration would be enormous, unfortunately I believe that I made some mistakes and considered to less thing, for example i don't considered vapourization(what should happen) and got equation:
a=(p1ST2-MgT1)/T1M OR a=(p1SUIt+cmT1(pS1-Mg))/cmT1M
p1- preasure at the beginning
S- area of the valve opening, for ex would be whole bottom
T2- water final temperature
M- mass of the whole rocket
g- I bet you know if not, better do not answer here
T1- water temperature at beginning
U-voltage
I-current
t- time
c- 4200 J/kg*K
m- mass of the water
So the problem might be unclear because English is not my born language, as you see...
Also some things might be called differantaly in different countries, like voltage (U, or V..) but physics is the same (:
So this topic involved all classical stuff: Mechanics, Electrodynamics, & Thermodynamics.
Main questions is how water would behave?
Thanks!
Don't try this at home:
And look at a steam table for what pressure and temperature are associated with each other as you heat the vessel.
excellent
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
