Heating Sand, Oil, Paraffin, and Salt Water in a Microwave
Heating oily sand in a microwave is possible, but the presence of paraffin and salt water raises questions about uniform heating. Microwaves can travel through a metal waveguide, but proper launching techniques and waveguide dimensions are crucial for effective transmission. Modifying a microwave oven is highly discouraged due to safety risks and the need for advanced knowledge. For practical applications, especially in fields like oil extraction, low-power experiments with safe equipment are recommended. Understanding waveguide specifications and microwave physics is essential for anyone considering such applications.
Garyt
If I tightly packed oily sand in my microwave and turned it on would it heat the sand and oil? If paraffin and salt water were present would it heat everything? Could I send the microwaves to the oven from 1 mile away thru a piece of metal conduit?
Science news on Phys.org
Microwaves will travel through a metal tube or 'waveguide' with an appropriate cross section. However, you need to launch the wave into the waveguide in the right way.
I would not advise that you get involved with modifying a microwave oven. There is a dangerous amount of power available (hundreds of Watts!) which can harm the human body.
You would need a professional level of knowledge to design, build and operate microwave equipment with that sort of Power. I will refer this to the Mods because it is a potentially dangerous practice and PF is not into that sort of thing, I'm afraid.
PS There are plenty of experiments that can be done using fairly inexpensive, low power equipment. You could approach the subject that way.
At Garyt, as sophiecentaur mentions, we can discuss the physics of microwaves here, but not the modification of microwave ovens (if you are asking this level of question then you do not have the knowledge to safey make modifications).
Microwaves can be routed through a waveguide, which is a tube of the right size. It would certainly be substantially lossy over long distances.
In an answer to my orginal question, It was stated that:Microwaves can be routed through a waveguide, which is a tube of the right size. It would certainly be substantially lossy over long distances. What is the correct size and define lossy. I am not modifying a microwave, just wondering if microwaves would work in a certain application in the oil field.
It was also stated that: Microwaves will travel through a metal tube or 'waveguide' with an appropriate cross section. However, you need to launch the wave into the waveguide in the right way. What would the appropriate cross section look like? How big would it be? What is needed to launch microwaves in the correct way?
One of the most common ways is with a monopole probe element in the waveguide an electrical 1/4 wave length from the closed end of the guide
its good for power levels up to 5 - 10 Watts or so
Another method is mounting a Gunn Diode at that same position instead of a probe ... Gunn Diode oscillators have power levels up to approx. 500mW
For really high power methods 10's to 100's of Watts cavity oscillators such as magnetrons and klystrons are used. These cavity oscillator units are coupled directly to the open end of the waveguide
Waveguides are essentially high pass filters. That is, they have a lower frequency cutoff value
depending on the specific type of WG. there is a whole range of WG's covering freq's from around 1000 MHz to 100+ GHz
for example WR75 is designed to cover the ~ 8 - 11GHz.
whereas WR42 is designed for ~ 18 - 26 GHz and 10 GHz won't pass through it without severe attenuationDave
See this link for an overview of waveguides: http://www.navymars.org/national/training/nmo_courses/NMO1/module11/14183_ch1.pdf
Input/output methods are covered starting at the bottom of page 28.
