Can a Toy Helicopter Be Programmed for Automatic Hovering?
Programming a toy helicopter for automatic hovering is feasible, as confirmed by multiple contributors in the discussion. The primary forces at play are gravity and lift generated by the rotors, which must be balanced for stable hovering. Achieving a stationary hover is challenging due to inherent movement along the plane, but using cameras for real-time tracking can help create a feedback loop to minimize this motion. Adjusting the throttle to find the optimal lift and experimenting with pitch and yaw are essential for improving stability.
  • Understanding of basic physics principles, particularly forces and motion.
  • Familiarity with control systems and feedback loops.
  • Knowledge of programming for real-time data processing.
  • Experience with toy helicopter mechanics and rotor dynamics.
  • Research PID (Proportional-Integral-Derivative) control for stabilizing hover.
  • Explore sensor integration for real-time position tracking.
  • Learn about the dynamics of rotorcraft and how to calculate lift and thrust.
  • Investigate weight distribution and trim adjustments for improved stability.
Hobbyists, robotics enthusiasts, and engineers interested in drone technology, particularly those focusing on stabilization and control systems for aerial vehicles.
Maor_M
Heya everybody,
I am trying to write a code that will make a toy helicopter to hover. I have cameras that are constantly tracking it, reporting at real time about it's position and angles.
I have control on the yaw (Z axis rotatio), pitch (forward/backward movement), and rotors speed.
I have basic knowledge in physics, so I ask two things:
1. Is it possible??
2. Someone can explain me what are the physical forces working on the helicopter, and if there are equations to balance it??
Thanks bodies...
1) Yes, of course it's possible. That's one of the most significant things about a helicopter, is its ability to hover.
2) Well, there are basically two forces, assuming that you keep it stationary in the horizontal direction. There is gravity, and then there is the lift of the helicopter caused by the spinning rotors "throwing" air underneath them.
But even when it's hover, it's not staying in position, and goes diagonal. Any attemp to change angles just make it worse.
Maor_M said:
Heya everybody,
1. Is it possible??
Thanks bodies...
In a relatively wind free environment? Yes it's possible for your toy helicopter to hover.
You need your lift to equal the downward force of gravity. The easiest way to do this would be to find the throttle sweet spot that allows hover.
You're never going to get a stationary hover with toy helicopters, there will always be some component of movement along the plane. You can minimize it by playing with the pitch/yaw.
W
What is that component??
Maor_M said:
Heya everybody,
1. Is it possible??
Thanks bodies...
I need stationary hover, or something close to it
Maor_M said:
WWhat is that component??
They're variable, depending on conditions. If you have cameras tracking the motion, you can create a feed back loop that will supply corrective inputs to minimize the motion.
Maor_M said:
Heya everybody,
1. Is it possible??
Thanks bodies...
what is your academic/professional background?
is this for a project?
the reason I ask, this can be a very complicated controls problem depending on the constraints and end goals.
Try adjusting the weight trim .
10K
  • · Replies 32 ·
13K
19K
