Help ~ Calculate the maximum noise voltage
The discussion focuses on calculating the maximum noise voltage induced in a circuit formed by two conductors in a magnetic field. The specific scenario involves conductors that are 10 cm long and spaced 1 cm apart, situated in a 10-gauss magnetic field at 60 Hz. A participant suggests that the maximum noise voltage is approximately 377 microvolts. The conversation emphasizes the need for the correct equation to calculate induced voltage from a changing magnetic field. Understanding electromagnetic principles is crucial for solving this problem effectively.
poon2009
Help!~ Calculate the maximum noise voltage
Two conductors, each 10-cm long and space 1-cm apart, form a circuit.
This circuit is located where there is a 10-gauss magnetic field at 60 Hz.
What is the maximum noise voltage coupled into the circuit from the
magnetic field?
From this book--Electromagnetic compatibility engineering- Chapter 2
http://books.google.com.hk/books?id...resnum=4&ved=0CDkQ6AEwAw#v=onepage&q&f=false"
377uV
Does anyone could teach me how to calculate it?
Thank you!
magnetic field?
377uV
Thank you!
The link does not appear to be translating...
In any case, what is the equation that you use to calculate the induced voltage around a wire loop from a changing magnetic field? That's what you should use here...
