Help calculation torque, moments.
The discussion revolves around calculating torque and moments for a uniform rod suspended by two strings, with a mass attached that causes the rod to pivot. The problem involves understanding the forces acting on the rod and the distances involved in the torque calculations.
  • Mixed
  • Participants explore the setup of the problem, questioning the placement of the mass and the correctness of the drawn diagrams. There are attempts to establish the moments about point P and clarify the notation used in the equations.
Several participants have provided insights into the torque calculations and the implications of the rod's position. There is ongoing clarification regarding the placement of the mass and the interpretation of the moments equation. Some participants express confusion about the notation and the approach taken by others.
Participants note the importance of understanding the pivot point and the distances involved, as well as the need to ensure that the calculations reflect the conditions stated in the problem. There is a reminder about the forum's guidelines regarding providing full solutions.
tweety1234
A uniform rod AB of length 4m and mass 2kg is suspended in a horizontal position by two vertical strings attached at points p and Q where AP=1m and AQ=3m. When a particle of mass 3kg is attached at point R of the rod, the rod is on the point of turning about point P. Calculate the distance AR.
As the rod is on the point of tilting about P than, Rp =0
I have drawn the diagram and have attached with this post, but i am not sure it is correct, and also I am not quite sure were to put point 'R' on my diagram.
the moments equation that I have come up with is;
taking moments about P
[tex]2kg + 3kg (xm-3m)=0[/tex]
[tex]2 \times 9.8 + 3 \times 9.8 (xm-3m) =0[/tex]
[tex]19.6 + 29.4x-88.2=0[/tex]
[tex]29.4x-68.2=0[/tex]
[tex]29.4x=68.2[/tex]
[tex]x = 2.3[/tex]
I think my moments equation is wrong, or my diagram, can anyone please show me where i am going wrong
thanks!
I'm a bit confused with your notation, I guess. what is m?
here is my attempt,
first off, don't forget that you are looking for WEIGHT, which is (mass)(gravity)
ok, if you draw your diagram, you will notice in order for the rod to move, the weight at point r has to be between AP, let's call A=0m and P=1m. Now draw the rods weight, and where it should be placed, in the center of the rod, or W=2m. notice now that the distance from P to the center of the rod must be 1m. since A=0m and W=2m, and since P=1m, the distance from P to W is 1m.
now just set up you equation, i used a variable "a" to represent the moment arm of the point r, but this distance measures rp not ar. but that is easy to solve, let start with the moment equation.
Mp=(3kg)(9.81kg/m2)(a)-(2kg)(9.81kg/m2)(1m)=0
solving for a we get a=2/3m
now remember what i said before a is the moment arm of the point r, measured from p. also remember for the rod to move, r has to be to the left of p. and since AP=1m, and rP=2/3m we arrive at our solution
Ar=1/3m
hopethis helps! this was my first time trying to explain something on this site hehehe
I presume that "xm" means x meters and "3m" means 3 m. But I don't know why you are calculating torque about Q. The problem says it is about to pivot about P, not Q. "AQ=3m" means that the distance from A to Q is 3 meters. Since the stick is 4 meters long that means that the stick has supports 1 meter from each end.
Since the mass of the rod is 2 kg, we can treat that as a downward force 2 m from A. A 3 kg mass is attached at point R, some unknown "x" meters from A.
If "the rod is on the point of turning about point P", the torque in both directions, clockwise and counter clockwise must be the same and the total torque 0 and the upward force at Q must be 0. That means we have only the weight of the rod, 2g N at 1 m from P and the 3g N force at R. Taking "to the right of P" to be positive, we have torque 2g N-m from the weight of the rod and torque 3g(x-1) (since P is itself 1 meter from A). The total torque is 3g(x-1)+ 2g= 0. Solve that for x.
It should be obvious that to offset the weight of the bar to the right of P, R must be to the left of P and x must be less than 1.
One of the things you should have learned from the things you were asked to read when you registered is that you should not give full solutions!
Hi,
thanks for all your replies but i don't really understand what everyone is saying...
I re-drawn my diagram, if anyone can have a look at it and tell me if it is correct ?
http://www.mathhelpforum.com/math-help/attachments/advanced-applied-math/9103d1228428259-mechanics-help-untitled.jpg
from this equation, shouldn't my moments equation be; [tex]2kg + 3kg (xm-3m)=0[/tex]? (taking moments about P)
WHOOPS! ill keep that in mind!
in your drawing, tweety, notice r is not in the appropriate place. because having the weight where you placed it would not make the bar rotate about point P, but Q instead...
Oh right, so should it be next to p instead?
yes! (in between p and a!)
  • · Replies 17 ·
