Help! Calibrating Rig for Moment Force
  • Thread starter Thread starter dotz5
    Calibration
The discussion revolves around calibrating a load cell for measuring lift, drag, and moment forces on an aerofoil. The user seeks guidance on how to apply weights to the moment axis, as they can only add weights on the x and y axes for lift and drag. Participants suggest considering the attachment of the test article to the load cell and using a dead weight to achieve the necessary loads. They also emphasize the importance of loading the cell correctly and recommend posting a clearer image of the setup for more specific assistance. Overall, the calibration process requires careful consideration of how forces are applied to ensure accurate measurements.
dotz5
Help! Calibration rig
Hi guys,
I'm new to engineering and currently, my school gave us a project to measure the lift, drag and moment forces acting on the aerofoil at various angle, but we need to do a calibration on the load cell which we will be using. But, how to we add weight on the moment axis to calibrate the moment force? we can only add weights on the x and y-axis to calibrate the lift and drag forces right??
Thank in advance and sorry for my bad english :shy:
I'm sorry, but I don't understand your picture. A photograph of the setup would be more helpful. Also, don't say 'moment force' - it's simply moment.
opps..sorry that was a rough sketch on the calibration rig that we are going to construct...
My lecturer told us to add weights on the drag, lift and moment axis and the computer should pick up the exact forces acting on the axis.
so we added weights on the x-axis for the drag and y-axis for the lift but how to we add weights on the moment axis which will be turning?
( erm... do we need to follow the direction of the forces? can we add weight on the Z axis instead of the moment axis?)
All I can say is think of how your test article is attached to the load cell. Now take a step back and think of how you can achieve the same loads but with a dead weight.
If you post a better picture of what the mount structure looks like we can can get into more in depth help.
When we calibrate torque meters and such, it gets as simple as a bar with a weight on the end. You just have to make sure you are loading the cell properly. I am assuming that you have a different transducer for the moment since it's usually not good practice to load a standard load cell in any direction other than it's main axis.
Please post a better picture.
I managed to find the picture of the load cell from the net..
And these are taken from my school...
Hope this helps...
Pilot training is critical to safe flying. I watched the following video regarding the crash of TAM 402 (31 October 1996), which crashed into a Sao Paolo neighorbood about 25 seconds after takeoff. https://en.wikipedia.org/wiki/TAM_Transportes_A%C3%A9reos_Regionais_Flight_402 The pilots were never trained to handle such an event (the airline had asked the manufacturer about training for this event), since it was considered too improbable (so rare) by the manufacturer. There was no...
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
