Help for electrical transformer?
This discussion addresses key questions regarding electrical transformers, specifically their polarities, power input-output relationships, and operational configurations. It confirms that while transformer polarities must be consistent, they operate with alternating current (AC) voltage, which cycles polarity. The input power is nearly equal to output power, accounting for losses such as eddy currents. Additionally, transformers are typically not operated in parallel due to potential load imbalances, but they can be connected in series, especially with multi-tap transformers for varying output voltages.
  • Understanding of AC voltage and its characteristics
  • Knowledge of transformer operation and efficiency
  • Familiarity with electrical losses, including eddy currents
  • Concepts of series and parallel electrical circuits
  • Research transformer efficiency and loss reduction techniques
  • Learn about multi-tap transformers and their applications
  • Study the principles of AC voltage and its effects on transformer operation
  • Explore best practices for connecting transformers in series and parallel
Electrical engineers, students studying power systems, and professionals involved in transformer design and application will benefit from this discussion.
neduet
Hello friends:
I need answer of my question please
Q.1 In electrical transformer polarities must be same or not
Q.2 if transformer under normal condition load is also normal. Is there power of input feed equal to power output? (My teacher said input power = to output power)
Q.3 Must careful things to parallel transformer or transformer can be operated in series if yes. Then why?
thank you very much ...
neduet said:
Hello friends:
are you referring to voltage polarities ? a Transformer operates with an AC Voltage
its polarity is constantly cycling
yes almost ... minus losses in the transformer (eddy currents etc that cause heating), nothing is perfect
I think you are asking abut operating transformers in series or parallel ??
you wouldn't normally operate them in parallel, as in parallelling the output (secondary) windings... because of the windings unlikely to be exactly the same, there will be an imbalance between load sharing of the windings
series connection of output (secondary windings) done all the time, multi-tap transformers are used for producing multiple output voltages
hopefully that helped :)
Dave
