Help in a tube about a laser ray
  • Thread starter Thread starter hagopbul
    Laser Ray Tube
hagopbul
i need a equation that discrip the movement of laser ray in the tube in a way that it won't get out
google for "total internal reflection".
the tube is open from the both ends
Sounds like some sort of pipe that is hollow if it can be described as "open at both ends".
ok it is a tube long about 100 cm i want to make a laser beam enter the tube in an angle and reflect severl times in this tube like the black body...were the laser enter the body and reflect in it until it is complitly absorbed ...but instead of rectangel with one entrance ...a tube with two entrance
So you need to know how well the material absorbs the laser light.
At each reflection, some is absorbed, some transmitted, and some reflected.
Depending on the tube material and the color of the laser, the absorption could be 100% at the first contact to almost nothing. iirc: it does not depend on the angle of the incident beam so you are only concerned to get enough reflections to absorb a significant percentage of the photons in the length of the tube.
yes and i need to know how to write an equation that makes the light reflect so many time in the tube that will traverse in the tube more than its length for example 100 time
Its the same as reflecting off two mirrors.
Lets say you want to reflect N times, in a tube length L and diameter D.
Put your laser on-axis, but angled towards one side.
If N=1, you need to aim the laser so it just grazes the edge of the entrance and hits half way down. If N=2, it's the same but aimed a third of the way down and so on. So you are making N+1 isosceles triangles, with height D and base 2L/(N+1). The angle of attack is therefore given by:
\tan\theta = L/(N+1)D
If you aim the beam well off-axis though, you can get more reflections spiraling around the outside. So you have quite a lot of freedom... the same sort of argument above can be used to find out how many reflections you get off-axis.The secret is to draw the picture.
simon you are the man...i want to be like you ...i can't transform my ideas into mathematical formulas ...what should i read or do to become like you
Lots of practise - drawing mostly.
Math is a language - you use almost the same way... picture what you want, draw it, turn it over in your mind and when you can feel it, describe it in math.
Turning words into a picture is usually the slow part.
Look how long it took to get the right picture of what you wanted.
