Help me construcing finite field,
  • Thread starter Thread starter Granit_niti
    Field Finite
To construct a finite field with q elements where 10^9 < q < 10^10, a prime number p and an integer n must be chosen such that p^n falls within this range. The construction involves using the field Z_p and an irreducible polynomial of degree n. Only one irreducible polynomial is necessary for the construction, not all possible irreducible ones. Tutorials on finite fields can provide additional guidance on the process. Understanding the basics of finite fields and irreducible polynomials is essential for successful construction.
Granit_niti
Help me construcing finite field, please!
I need Construct a finite field with q Elements (10^9<q<10^10) and find
a primitive root. That should be done in mathematica but I should not use Package for Finite Fields.
Any idea how to solve this problem?
What do you know about fields?
Do you have any examples of fields?
I don’t think this is pre-calc, but:
Can you think of a number p and n where
10^9 < p^n < 10^10
you should know how to construct a field with p^n elements.
Hint: It involves Z_p and a irreducible polynomial of order n (check your class notes!)
Edit: p must be prime of course
Thank you very much!
Could you refer me to any tutorial for constructing field with p^n elements the?
I am not good with fields at all!
When I construct the field do I have to take all polynomials possible of n degree in Z/Zp or only one irreducible or all irreducible ones?
I don't have clear what is the finite field. What do I have to find in order to construct finite field?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
