chel
- 14
0.5Kg snowball moving at 20m/s strikes and sticks to a 70Kg man standing on the frictionless surface of a frozen pond. what is the final velocity?
The discussion centers on calculating the final velocity of a 0.5 kg snowball moving at 20 m/s after it collides and sticks to a 70 kg man on a frictionless surface. The conservation of momentum principle is applied, leading to the equation (0.5 kg * 20 m/s) + (70 kg * 0 m/s) = (0.5 kg + 70 kg) * V_final. The final velocity is determined to be approximately 0.14 m/s. Participants emphasize the importance of understanding momentum conservation and the impact of mass on the outcome of collisions.
PREREQUISITESStudents learning physics, educators teaching momentum concepts, and anyone interested in understanding collision dynamics and conservation laws.
No. To find the total momentum of the system, just add up the momentum of each part. What's the initial momentum of the snowball? Of the man?chel said:uhmm, the momentum before and after the collision was zero?
chel said:can i use this formula?
(0.5kg)*(20m/s)+(70kg)(0m/s)=(0.5kg+70kg)(Vafter)?
10kg.m/s=(70.5kg)(Vafter)
Vafter=10kg.m/s / 70.5kg
= 0.14m/s
Cyosis said:Tama ako? Anyway yes you found the correct method and answer to your problem.
Cyosis said:It's a matter of significant digits really.
The correct equation to use was m_{sb} v_{sb}+m_{man}v_{man}=(m_{sb}+m_{man}) v_{final}. The interesting part is (m_{sb}+m_{man}) =70.5kg.
The equation you used the first time was m_{sb} v_{sb}+m_{man}v_{man}=m_{man} v_{final}. Here you are ignoring that when a snowball is stuck to a man his total mass is increased. Because the snowball is so light both equations gave the same answer with a 2-decimal accuracy. Try to recalculate it by saying that the mass of the snowball is 100kg, keep the rest of the numbers the same. You will see that your answer is very different.
More intuitively: If I throw a snowball at you, you won't move much because its mass is low. If I were to throw a wrecking ball at you, you would move quite a bit since its mass is high compared to yours, assuming both snowball and wrecking ball hit you at the same speed.
