How Does Induction Heating Work and What Factors Affect Its Efficiency?
Induction heating efficiency can vary based on the power available, such as 8800 Watts or 220V at 40 Amps, and the specific characteristics of the iron object being heated, including its size, shape, and thickness. The depth of heat penetration and the time required to reach desired temperatures are critical factors, particularly for geometries like a 1/4-inch iron pipe. Using RF coils in the range of 20-100 kHz may effectively heat materials like copper pipes. For precise calculations and efficiency insights, consulting an induction heating company is recommended. Understanding these variables is essential for optimizing the heating process.
infoseeker39
What is the efficiency of induction heating? What if you only had 8800 Watts available, or perhaps 220V, 40Amp... what size iron object could you heat, and to what temperature? Size will have to be qualified... how long? What shape & how thick? Depth of heat penetration. Then how long would it take to heat this object. Now what if this was an iron pipe, let's say 1/4inch... then we passed water through it? Sorry, but I have a lot to learn...
Science news on Phys.org
I assume you are interested in a pipe geometry, and not a flat plate. There are RF stoves that heat pots and pans with copper bottoms. I suspect that an RF coil (20 - 100 kHz) in the form of a solenoid could heat a copper pipe. I would contact an induction heating company like:
http://www.mtixtl.com/sp-15adest-topinductionheater20-100khz7kw.aspx
They could give you information on heating efficiency.
Bob S
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
