Help needed to convert angular velocity to angular acceleration
The discussion revolves around the calculation of angular acceleration (α) given an angular velocity (ω) of 5 rad/s, mass (M) of 4 kg, radius (R) of 2 m, and a time period (T) of 3 seconds for one revolution. Participants explore the relationship between angular velocity and angular acceleration, as well as the conditions under which these quantities can be calculated.
  • One participant states that the angular acceleration is zero unless additional information about the change in angular velocity is provided.
  • Another participant questions whether the inquiry is about angular acceleration or centripetal acceleration, suggesting that the data provided may not be sufficient.
  • Some participants propose converting angular velocity to tangential velocity and then relating it to centripetal acceleration, while noting that angular acceleration is related to tangential acceleration.
  • A participant emphasizes the need for clarification on the motion's conditions, such as whether it is moving with constant speed or starting from rest.
  • There is a discussion about the inconsistency between the given angular velocity and the time period for one revolution, suggesting that if T=3s, the angular velocity should be approximately 2 rad/s.
Participants generally agree that the angular acceleration is zero if the angular velocity is constant. However, there is disagreement regarding the sufficiency of the provided data and whether the focus should be on angular or centripetal acceleration.
The discussion highlights potential limitations in the problem statement, including missing assumptions about the motion and the relationship between angular velocity and time period.
sherazi21st
hi,
I've calculated
ω=5 rad/s
How can I calculate angular acceleration (α)
I've Mass, M=4Kg
Radius, R = 2m
and time taken by each single revolution, T=3sec.
Unless you forgot to tell us something, the angular acceleration is zero!
I've only this data, what is missing?
How the angular velocity is changing.
Are you sure you want angular acceleration, not centripetal acceleration?
I had also the same point but I got this data only. I thought there may be any method to convert this by either convert this ang. vel. to tang. vel. by rw and then it might be converted into angular acc. by using definition of centripetal acc. or something else if I'm not wrong.
Angular acceleration is related to tangential acceleration, not centripetal acceleration. But all you gave us is an angular velocity.
You need to describe what you are being asked to find in more detail. What did you measure? What physics topic are you studying now?
Can you tell me how will we calculate Centripetal acceleration? Just by converting w into v and then putting v in v^2/r. Am I correct?
Dear, I'm studying Angular acceleration and angular velocity. I am given only radius of the horizontal circle in which a mass m is moving and completes one revolution in t seconds. I guess there is fault in the question.
Sure. You can also use this equivalent expression and save yourself the conversion: ac = ω2r
Is it moving with constant speed, or does it start from rest (for instance)?
constant w
sherazi21st said:
constant w
In that case, the angular acceleration is zero, as pointed out by russ_watters earlier.
sherazi21st said:
hi,
I've calculated
ω=5 rad/s
I've Mass, M=4Kg
Radius, R = 2m
It's either T =3s OR w=5 rad/s.
You cannot have both for the same motion, with constant angular speed.
If T=3s, the angular velocity is about 2 rad/s.
  • · Replies 138 ·
9K
  • · Replies 21 ·
20K
  • · Replies 41 ·
