How Does Positive Second Derivative Imply Function Convexity in Calculus?
In summary, the conversation discusses how to solve a derivative of a function and the conditions for this function to be convex. The expert explains that the function can be an exponential, sine, cosine, quadratic polynomial, or constant, and that it must be continuous and twice differentiable. The expert also mentions that the function must be positive on the interval and that there is a point where the function is positive. The expert then clarifies how $f''(x_1) > 0$ implies that $f(x_1) > 0$ by using the definition of convexity.
Amad27
412
I recently searched around SE, and found:
[How to solve this derivative of f proof][1] [1]: calculus - How to solve this derivative of f proof? - Mathematics Stack Exchange
The answer is interesting.
"A function given that $f(x)=f''(x)+f'(x)g(x)$ could be an exponential function, sine, cosine , quadratic polynomial or $f\equiv0$. So we can say that the function is a continuous function $\in C^2$.
The right negation is that $f(x)\ge0$ in $(a,b)$ and exist a point c | $f(c)>0$.
You have that $f''(x_1)\ge0$ (the function in that point is convex) so in that point you have a minima so there are two case
1. $f(x_1)<0$ (obviously contradiction)
2. $f(x_1)=0$ (it's impossible because this imply that $f(x)=0$ $ \forall x \in (a,b) $)
Analog for the other case"
But how does $f''(x_1) > 0$ show that $f(x_1) < 0$?
Thanks!
Thank you for bringing up this question. To answer your question, let's first recall the definition of convexity: a function $f(x)$ is convex on an interval if for any two points $x_1$ and $x_2$ in that interval, the function lies above the line connecting these two points. This can also be stated as $f(\lambda x_1 + (1-\lambda)x_2) \leq \lambda f(x_1) + (1-\lambda)f(x_2)$, where $\lambda$ is a value between 0 and 1.
Now, let's consider the point $x_1$ where $f''(x_1) > 0$. This means that the second derivative of $f(x)$ at this point is positive, which implies that the function is concave up. In other words, the function lies above the tangent line at this point. From the definition of convexity, we know that the function must also lie above the line connecting $x_1$ and any other point $x_2$ in the interval.
Now, if $f(x_1) < 0$, then the function would lie below the tangent line at $x_1$, which contradicts our assumption that the function is convex at this point. Therefore, we can conclude that $f(x_1) > 0$. I hope this helps to clarify the proof for you.
FAQ: How Does Positive Second Derivative Imply Function Convexity in Calculus?
1. What is a derivative proof?
A derivative proof is a mathematical method used to find the rate of change of a function at a specific point. It involves using the limit definition of a derivative to find the slope of a tangent line to the function at that point.
2. Why is a derivative proof important?
A derivative proof is important because it allows us to find the instantaneous rate of change of a function, which is crucial in areas such as physics, economics, and engineering. It also helps us understand the behavior of a function and how it changes over time.
3. What is the process for solving a derivative proof?
The process for solving a derivative proof involves three main steps: 1) setting up the limit definition of a derivative, 2) simplifying the expression using algebraic rules, and 3) taking the limit as the independent variable approaches the specific point. This will give us the slope of the tangent line at that point.
4. What are some common mistakes to avoid when solving a derivative proof?
Some common mistakes to avoid when solving a derivative proof include not properly using the limit definition, making errors in algebraic simplification, and forgetting to take the limit at the end. It is also important to pay attention to the domain of the function and any potential discontinuities.
5. How can I improve my skills in solving derivative proofs?
To improve your skills in solving derivative proofs, it is important to practice regularly and familiarize yourself with the various rules and formulas involved. You can also seek help from a tutor or attend workshops or online courses that focus on calculus and derivatives. Additionally, reading and understanding the derivations of different proofs can also enhance your understanding and problem-solving abilities.
