Help needed with charge sensitive amplifier circuit
The discussion revolves around the design and troubleshooting of a charge-sensitive amplifier (CSPA) circuit used for radiation measurement readout front-end electronics. Participants explore the behavior of the circuit when interfaced with a photodiode and discuss discrepancies between theoretical expectations and experimental results.
  • Experimental/applied
  • One participant describes their experimental setup using an OPA657 operational amplifier with a photodiode, noting that the output pulse width matches the input pulse width rather than exhibiting the expected decay based on the Rf and Cf time constant.
  • Another participant points out a potential issue with the power supply voltage, suggesting that the circuit may be incorrectly powered.
  • A participant proposes reversing the photodiode connection and adding a capacitor to improve performance, referencing the datasheet for guidance.
  • Concerns are raised about the properties of op-amp simulation models affecting the results, with one participant sharing their own difficulties in simulating similar circuits.
  • Another participant clarifies that the circuit functions as a preamplifier rather than a differentiator, which could explain the output behavior observed.
Participants express differing views on the cause of the output behavior, with some suggesting circuit configuration issues while others consider the properties of the components used. No consensus is reached regarding the underlying problem or solution.
Participants mention various assumptions about the circuit configuration, including the power supply voltage and the intended function of the op-amp. There are unresolved questions about the time constant calculations and the expected behavior of the circuit.
This discussion may be of interest to those involved in electronics design, particularly in the context of radiation detection and signal processing using charge-sensitive amplifiers.
mohindar
hello sir, we are designing radiation measurement readout front-end electronics, as part of our project ,in very 1st step to understand working of CSPA(charge amplifier) i had done little experiment by connecting photodiode with opa657 .here i have used general purpose ir photodiode and Rf=147k ohm, Cf= 1pf. in feedback with opa657. i am giving 5v pulse train having 50ns pulse width and 2Mhz repetition rate to IR LED which is placed very near to IR photodiode which simulated as radiation source and photodiode will work as detector. now problem is as per theory output of cspa have long decaying pulse having time constant equals to Rf.Cf , but in my experiment cspa output is same like input pulse having 70ns width and 350mV peak amplitude .can you please tell where i am making mistake? i don't understand what's wrong with this circuit. http://file:///C:/Users/Administrator/AppData/OICE_15_974FA576_32C1D314_8B1/msohtmlclip1/01/clip_image002.jpg
hi there
welcome to PF :)
can you please repost, better still upload your circuit image to the forum
as at the moment it isn't visible
regards
Dave
here is circuit attached.
OK to make it easier to read ...
can you please tell me where i am making mistake in my experiment ? why its output signal has same pulse width as input signal according to theory output pulse is decaying step signal with RfCf time constant.
OK
first major problem is that you are supplying it +- 12V when its maximum is +- 6V
oppsss... that is mistake in circuit diagram...in actual circuit i have used +5v and -5v power supply..rest of component according to above post.
thank you for your quick reply. my main doubt is that is it ok to use opa657 for this experiment? and for testing it with ir photodiode ?
OK no probs :)
you mite like to try 2 other things to come in line with what is shown in the datasheet
reverse the photodiode and connect its cathode to -V rather than common(GND) rail
place a ~ 50pF cap from the -in of the op=amp to common
I haven't played with op-amps for this particular purpose before, my stuff has all be low noise high gain for
seismic signal amplification before the ADC circuitry
Dave
yes i have already done that reversing that photodiode , but output is same ! main problem is that Cf should discharge with Cf.Rf time constant but here it is discharging within 70ns but in circuit time constant is in terms of us.
I had similar problems and couldnot undestand still. This made me think that the situation is about the properties of opamp simulation models. All my treatments about simulating especially such small signal stuff was unsuccefull. But you may find some solution when you look at from this view.
Calculation: T=147ns , OK? And you are measuring (simulation) 50% of this ? So the problem is a factor of 2, right?
What do you mean with "in circuit time constant is in terms of us"?
I gather you're trying to differentiate your input signal?
Recheck that theory...
Your circuit has DC gain, so it's a preamplifier not a differentiator.
so i'd expect output to be same shape as input with perhaps slower rise and fall times.
See fig 2 here:
http://freshlab.org/detektor/?lang=eng
first amplifier inside "amplifier & shaper" block is a differentiator.
It will produce 'decaying pulses' like you describe.
a quick google search turned up this page which looks at first glance to be rich with detail
http://iopscience.iop.org/0031-9155/55/7/003/pdf/pmb10_7_003.pdf
but I'm not well versed in such circuits.
good luck,
old jim
  • · Replies 152 ·
13K
