Help regarding normalization of wave functions
11 replies · 2K views
legend
Hi, i need some help regarding normalization of a wave function, i feel it is a very simple problem, but i am having a hard time figuring it out. I would really appreciate it if anybody could help me out a bit regarding this.
I need to normalize the following wavefunctions by figuring out the constant B.
(1) ψ(x) = Bexp(ikx) where ψ(x) is non‐zero between x=0 and x=L ;
(2) ψ(x) = Bexp(−kx) where ψ(x) is non‐zero between x=0 and x=∞
Thanks a lot in advance.
|ψ(x)|² = 1
So legend square both sides, set |ψ(x)|² equal to one. then solve for B
Thanks a lot dacruick.
@jtbell... actually i have some vague idea, i am still in the process of coming to terms with quantum mechanics (i don't have a physics background :-( )
dacruick said:
|ψ(x)|² = 1
No, you also have to integrate. In general:
[tex]\int^{+\infty}_{-\infty}{|\psi(x)|^2 dx}<br /> = \int^{+\infty}_{-\infty}{\psi^*(x)\psi(x) dx} = 1[/tex]
In this case, one actually has to integrate only over the region where [itex]\psi(x)[/itex] is non-zero.
If [tex]\psi(x)[/tex] is a period wave with period L or it is in a box
[tex]\int^{+L}_{0}{|\psi(x)|^2 dx}<br /> = \int^{+L}_{0}{\psi^*(x)\psi(x) dx} = 1[/tex]
Thanks a lot for your answers. I have one doubt.
How do i go about the second function i.e Bexp(−kx)? Do i replace "-k" by "i²k" and proceed?
The wave function is real so [tex]\psi=\psi^*=Be^{-kx}[/tex]. Just integrate as it is and you'll be fine. (Replacing [tex]-k\to i^2k[/tex] will also give the correct answer because it actually does nothing. You don't have to do that.)
Thanks a lot to all of you guys for your help. So i solved them and got the following results. Could anyone please let me know if they are correct?
For number 1 : B = 1/(√L)
For number 2 : B = √(2k)
Yes, they are correct.
