Help with a Newtons Cooling Law Problem
The discussion revolves around solving a Newton's Cooling Law problem to determine the temperature of an oven based on thermometer readings. The initial approach involved setting up equations based on temperature changes over time, leading to a complex expression for the cooling constant, k. Participants suggested a simpler method by focusing on the temperature changes during specific intervals, which ultimately clarified the calculations. The correct final temperature of the oven was determined to be 390°F. Overall, the conversation highlighted the importance of simplifying calculations and verifying signs in equations.
ZeromusX99
A thermometer reading 70o F is placed in an oven preheated to a constant temperature. Through a glass window in the over door, an observer records that the thermometer reads 110o F after 1/2 minute and 145o F after 1 minute. How hot is the oven.
T(t)=(To-TR)ekt+TR
Ok so I let said
TR= Oven Temperature
To=70
To(.5)=110
To(1)=145
I then set up the general equation as
T(t) = (70-TR)ekt+TR
Then using the two times and temperatures I was given I created these two equations.
145=(70-TR)ek+TR
110=(70-TR)e.5k+TR
I then moved over the TR on the end over to the left side giving me these two equations
145-TR=(70-TR)ek
110-TR=(70-TR)e.5k
Dividing the top equation by the bottom i get
(145-TR)/(110-TR)=e.5k
Taking the natural log of both sides and then dividing by .5 gets me
k= 2*ln((145-TR)/(110-TR))
To me this seems like I may have overcomplicated something or made a mistake as plugging that value of k back into the equation seems like it would make solving for TR incredibly difficult, not even sure how I would be able to solve for TR using that value for k.
So what I'm asking is if the steps I took were the right ones to do and if I should go ahead and try to solve for TR using that value for k or if there is a simpler way. Thanks in advance.
Welcome to PF, ZeromusX99.
You did all the hard work already!
145-TR=(70-TR)ek
110-TR=(70-TR)e.5k
From this last equation, you can substitute your expression for e.5k into 110-TR=(70-TR)e.5k and solve for TR.
ZeromusX99 said:
T(t)=(To-TR)ekt+TR
Whoa! This would say the final temperature is either plus or minus infinity.
You have a sign error.
<Long, tedious calculation elided>To me this seems like I may have overcomplicated something ...
Using your result, k= 2*ln((145-TR)/(110-TR)), what is e.5k? (It isn't all that complex.)
Note well: This is a valid approach but it will of course yield the wrong answer because of your sign error.Aside: There is a much easier approach. What happened in the second half minute?
EDIT
Your approach is fine. It will just happen to yield a negative value for k.
The comment about an easier approach is still valid.
Thanks for the suggestion Billy Bob substituting for e.5k worked, guess I was just over thinking things.
Also, thanks to your suggestion D H of looking at the second half minute, where temperature increased by 35, I found the simpler way of doing the calculation TR, I'll go ahead and post it here
Instead of dividing I just subtract the equations I initially listed to get
35 = (70-TR)(e-k-e-.5k
Then do another subtraction of equations using my T(.5) and T(0)
110 = (70-TR)(e-.5k+TR
70 = (70-TR)+TR
I get
40 = (70-TR)(e-.5k-1)
dividing my
35 = (70-TR)(e-k-e-.5k)
by
then gets me
7/8 = (e-k-e-.5k)/(e-.5k-1)
pulling an e-.5k from the numerator then gives me
7/8 = e-.5k(e-.5k-1)/(e-.5k-1)
(e-.5k-1) cancels leaving me with
7/8 = e-.5k
natural of both sides gives me ln(7/8) = -.5k so
k= -2ln(7/8)
Plugging this into my equation
gives me
40 = (70-TR)(eln(7/8)-1)
which is just
40 = (70-TR)((7/8)-1)
leaving me with
40 = (70-TR)(-1/8)
multipling both sides by -1/8 gives me
-320 = 70 - TR[/SUB
Add TR and 320 to both sides then gives me
TR[/SUB = 390
Hehe next time I'll remember to make it -kt as well
ZeromusX99 said:
TR = 390
Correct.
You didn't quite get the gist of my hint.
Write Newton's law of cooling as
T(t)-T_R = (T_0-T_R)e^{-kt}
During the first half minute the temperature rose from 70o F to 110o F:
110-T_R = (70-T_R)e^{-kt/2}
from which
e^{-kt/2} = \frac{110-T_R}{70-T_R}
During the next half minute the temperature rose from 110o F to 145oo F. Thus
145-T_R = (110-T_R)e^{-kt/2}
Substituting the expression for \exp(-kt/2) in the above,
(145-T_R)(70-T_R) = (110-T_R)^2
Simplifying,
\aligned<br /> 10150-215T_R+T_R^2 &amp;= 12100-220T_R+T_R^2 \\<br /> (220-215)T_R &amp;= (12100-10150) \\<br /> T_R &amp;=390<br /> \endaligned
Ah I understand now thanks for all the help D H
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
15K
24K
