Help with a pipe, water, continuity and Bernoullie
The discussion revolves around solving a fluid dynamics problem using Bernoulli's equation and the continuity equation. The initial conditions include a water speed of 3.0 m/s and a gauge pressure of 5.0 x 10^4 at a higher point in the pipeline. The user calculates the speed at a lower point in the pipe, finding it to be 0.75 m/s due to the pipe's diameter being twice as large. After correctly applying the height difference in Bernoulli's equation, the user arrives at a gauge pressure of 162018.75, confirming it as the correct solution. The conversation highlights the importance of accurately defining height variables in fluid dynamics calculations.
TFM
[SOLVED] Help with a pipe, water, continuity and Bernoullie
At one point in a pipeline the water's speed is: 3.0 m/s,
the gauge pressure is: 5.0*10^4.
Find the gauge pressure at a second point in the line, 11m lower than the first, if the pipe diameter at the second point is twice that at the first.
Bernoullies Equation: P1 + density*g*y1 + 0.5*density*v1^2 = P2 + density*g*y2 + 0.5*density*v2^2
Continuity Equation: A1V1 = A2V2
I work out the speed of v2 using continuity, with area-1 being pi*r^2, Area-2 being pi*4r^2,
This makes the speed 3/4 m/s
I themn put all known variables into Bernoullies equation, which gives me a negative pressure! (-53581.25) this cannot be right?
Any Ideas/Suggestions
TFM
Looks good.
No, it can't. What did you put for y1 & y2?
I first put y1 as 0, y2 as 11, then tried y1 as 1, y2 as 12
It should be y2 = -11, shouldn't it? -goves an answer of 162018.75
Yep.
162018 was the right answer:smile:
Thanks
TFM
