Help with a statics/dynamics question?
  • Thread starter Thread starter DrVirz
7 replies · 1K views
DrVirz
Hi all,
I often find myself on this forum when searching google for help on certain topcis, but I only just joined :)
I am having trouble with a homework question. The question states:
If the rod starts from rest in the position shown and a motor drives it for a short time with an angular acceleration of Alpha = (1.5e^t ) rad/s2 , where t is in seconds, determine the magnitude of the angular velocity and the angular displacement of the rod when t = 3s. Locate the point on the rod which has the greatest velocity and acceleration, and compute the magnitudes of the velocity and acceleration of this point when t = 3s. The rod is defined by z = 0.25 sin(Pi y) m, where the argument for the sine is given in radians and y is in meters.
I have attempted the first section, which I think is correct however it seems too simple/odd to me.
Here is a link to the actual question (with diagram), and my working so far.
http://i1374.photobucket.com/albums/ag430/Drvirz/Problem 1_zpsidqrzizz.jpg
https://www.dropbox.com/s/7ibtkysyvxxag64/DSC_0124.JPG?dl=0
If anyone could confirm this is correct/incorrect and provide an insight into the rest of the question that would be fantastic!
Thanks in advance!
Josh
You appear to have integrated correctly to find the angular velocity function. But it says to solve it for when t=3. As for the next part try to find an equation for the angular displacement of the rod with respect to time.
You forgot the constants of integration in ur equations, should be easy to that the first constant for the angular velocity is -3/2, you should also compute the second for the equation of theta.
The point with the maximum velocity and acceleration is that with the maximum z. You should find the y for which z becomes maximum. Then the velocity is [itex]ωz_{max}[/itex] and the acceleration is [itex]Alphaz_{max}[/itex].
Never mind you already did that. Then you should ask yourself which part of the rod has the greatest velocity. The equation v= ωr should help...
Sorry SteamKing, I will take note for future, and also read the rules.
Just noticed your second comment. I will try and work through the next section and see how i go
Ok so more or less z=0.25sin(Pi*y) for 0<y<1
So find Z(max) by subbing y-value between 0-1 that will give largest z?
