Help with basic problem of kinematics
The discussion revolves around a kinematics problem involving an object thrown from a height, where the forces acting on it include gravity and air resistance proportional to its velocity. Participants explore the derivation of the velocity function over time, particularly focusing on the differential equation that describes the motion.
  • Homework-related
  • One participant presents the differential equation derived from Newton's second law, indicating the forces acting on the object.
  • Another participant seeks clarification on how the textbook arrived at the proposed solution for velocity, questioning the derivation process.
  • A third participant suggests that the equation is a first-order differential equation and mentions the use of an integrating factor for solving it, inviting further inquiries if needed.
  • One participant references a Wikipedia article on differential equations, noting the historical context of how such equations have been solved and the mathematicians involved.
  • Another participant reiterates that the equation is a differential equation and emphasizes that solving it yields the function for velocity as a function of time.
  • A final participant expresses gratitude for the responses and indicates that they have understood the problem after the discussion.
Participants do not reach a consensus on the derivation process of the velocity function, and there are multiple approaches and explanations offered without resolving the initial question about the derivation.
The discussion includes various assumptions regarding the initial conditions and the method of solving the differential equation, which are not fully explored or resolved.
sleepwalker27
Well, the problem says:
From some height a object with mass m is thrown . Determinate the law that describes how the velocity of fall v changes, if on the object, besides gravity, acts the force air resistance, which is proportional to velocity v (the proportionality coefficient is k), ie must be found v= f(t)
Then, by the second Newton's law, we have.
$$m\cdot\frac{dv}{dt}=mg-kv$$
AND THEN, HERE'S WHAT I DON'T UNDERSTAND. My textbook says:
Is easy to proof that every function:
$$v=Ce^{-\frac{k}{m}t}+\frac{mg}{k}$$
Satisfies the first equation.
Can somebody explain me in detail, why is that true? Thanks.
I think i asked de wrong question, the correct is: How the autor of the book came to that equation?
It is just a first order differential equation that can be solved by multiplying both sides of the equation by an integrating factor ##U(t)##. Look it up. If you need more help let us know.
If you want to check (or proof) that it works, then just plug the solution ##v## into the differential equation.
The constant ##C## can be determine by providing the required initial conditions.
Edited: fixed a mistake regarding the method of solving the equation
There's some history in the wiki article and while it doesn't directly answer your question may be helpful in finding the answer:
https://en.wikipedia.org/wiki/Differential_equation
I know when I first took this course it was like magic. I too wondered how these were discovered but alas it was never really discussed instead we were given recipes to identify the types of DEs and knowing that follow a few simple steps to gain the set of solutions.
Anyway from the article you can see how mathematicians like d'Alembert, Bernoulli, Lagrange and Euler took the codified knowledge of Calculus and extended to solve many common DE problems needed in physics.
Is a differential equation, if you solve it you get that function v (t)
Thank you all for your responses and your time, you helped me a lot.. I understood the problem
  • · Replies 0 ·
  • · Replies 21 ·
  • · Replies 78 ·
