Help with circular motion of zero gravity
To determine how long a day would need to be for a person at the equator to experience zero weight on a bathroom scale, the centripetal force must equal gravitational force. The radius of the Earth is known to be 6377.34 km, and the relevant equation is Fc = m(v^2)/r. The mass cancels out in the equation, simplifying the problem to finding the speed (v) at which centripetal acceleration equals gravitational acceleration (g = 9.8 m/s²). The discussion emphasizes understanding the relationship between centripetal force and gravitational force to solve for the required rotational speed.
koopa347
How long would the day have to be in order that for a person standing at the equator of the Earth would see a bathroom scale that she is standing on read zero?
This is all the info that is given.
Fc=m(v^2)/r
I setup my force equations so the sum of f=Fc=Fn-Fg. I then found out the radius of the earth, and this is where i got stuck , i know that the radius of the Earth is 6377.34km, but how do i figure out v and m; if v has to be greater than Earth's current centripetal force?
Welcome to PF
You're spinning so fast that gravity is just barely providing enough force to keep you in your circular "orbit." In other words, the centripetal force required for this orbit is equal to your weight (which is why you feel no normal force, which as you've correctly stated, is the difference between the two).
If the centripetal force is equal to the weight, and both are proportional to m, then m cancels from both sides of the equation (the mass of the object in the orbit doesn't matter). Hence you're finding the speed at which the centripetal acceleration equals g. You know r. You know g. You just have to solve for v.
What do you mean by both are proportional to m? Could you type out an equation that shows this step? Do you just mean
(m)(9.8)=mv^2/r
so those m's cancel, so we know now that we're left with 9.8=v^2/r?
(m)(9.8)=mv^2/r
Yes, that's exactly what I meant. To be proportional to "x" means to be equal to "x" multiplied by some factor.
