Help with coordinate transformations
The discussion revolves around understanding coordinate transformations in the context of vector fields, particularly in electrodynamics. The original poster is exploring the relationship between the vector potential and the magnetic field when changing coordinate systems through rotation.
  • Conceptual clarification, Assumption checking, Mixed
  • The original poster attempts to apply coordinate transformations to the vector potential and magnetic field, questioning the implications of these transformations on the resulting magnetic field. Some participants suggest that the magnetic field is not merely a vector and that rotation can lead to the emergence of a magnetic field, while others challenge this perspective by emphasizing the need for careful treatment of vector components.
Participants are actively engaging with the original poster's attempts, providing feedback on the correctness of the transformations and discussing the nature of the magnetic field. There is a recognition of potential errors in sign and factors, and some guidance is offered regarding the treatment of vector quantities during transformations.
The discussion highlights the challenges of identifying sign errors and factors in mathematical expressions, with participants sharing personal experiences related to error detection in both mathematical and written contexts.
frogster
I'm having trouble understanding coordinate transformations for vector fields. There are two 'coordinate pieces', the coordinates pieces of the vector at a point changes, and the function describing the field can also be rewritten in terms of the new coordinates. I'm having trouble being precise enough in my math to understand this. Precision is the key. So please be as pedantic as you want.
Here's an example for us to work on --
In electrodynamics, given the vector potential [itex]\vec{A}[/itex], the magnetic field is defined as:
[tex]\vec{B} = \nabla \times \vec{A}[/tex]
In coordinate system number S we have
[tex]A_x=x,A_y=0,A_z=0[/tex]
In coordinate system S', related to S by a rotation about the Z-axis. What is B? Also calculate A, and determine B this way as well.
To change coordinate systems by rotating about the z-axis.
[tex]x' = \cos(\theta) x - \sin(\theta) y[/tex]
[tex]y' = \sin(\theta) x + \cos(\theta) y[/tex]
And the inverse is just
[tex]x = \cos(\theta) x' + \sin(\theta) y'[/tex]
[tex]y = -\sin(\theta) x' + \cos(\theta) y'[/tex]
In coordinate system S, we have
[tex]\vec{B} = \nabla \times \vec{A} = 0[/tex]
rotating this vector just trivially gives in S'
[tex]\vec{B'} = 0[/tex]
Now to trying to rotate A
[tex]A'_{x'} = \cos(\theta) x,\ A'_{y'} = - \sin(\theta) x,\ A'_{z'} = 0[/tex]
[tex]A'_{x'} = \cos(\theta) (\cos(\theta)x' + \sin(\theta)y'),\ A'_{y'} = - \sin(\theta) (\cos(\theta)x' + \sin(\theta)y'),\ A'_{z'} = 0[/tex]
But now we have
[tex]B'_{x'}=0,\ B'_{y'}=0,\ B'_{z'}=\frac{\partial}{\partial x'} A'_{y'} - \frac{\partial}{\partial y'} A'_{x'} \neq 0[/tex]
[tex]\vec{B'} \neq 0[/tex]
This disagrees with above, and clearly a magnetic field shouldn't suddenly appear just because I rotated my coordinate system, so I must be doing something wrong.
What you have done is right! You have stumbled upon the fact that the magnetic field B is not really a vector. It is part of a two-tensor called the field strength tensor. Rotation does actually give rise to magnetic field.
It does most emphatically NOT! A is a vector. You should have rotated A just like you rotated the coordinates. A_x'=cos(theta)*A_x and A_y'=sin(theta)*A_x. You have a sign mistake. You don't start mixing electric and magnetic fields until you start doing special relativity with boosts. A rotation won't do it.
Doh! It seems so obvious now.
Thanks. I always have trouble finding factors of two and sign errors. Sometimes if I take a break and then work out the problem from scratch, I can fix the errors, but for some reason I can never find them staring at the math ... like my brain skips over it because it "knew what I meant" or something. I have the same problem with spelling mistakes in essays.
Besides just reworking the problem, do you guys have any suggestions from experience for how to find sign errors? Thanks.
  • · Replies 31 ·
  • · Replies 16 ·
