Help with electromagnetics: the Poynting Vector and Ampere contradiction
The discussion revolves around the Poynting vector and its implications in the context of a steady-state DC current-carrying wire. Participants explore the relationship between the Poynting vector, electric field (E), current density (J), and magnetic field (H), particularly addressing apparent contradictions in their behavior at the center of the conductor.
  • One participant notes that the divergence of the Poynting vector should not be zero due to the presence of a uniform electric field and current density, raising a contradiction with Ampere's law.
  • Another participant questions why the divergence is considered zero, suggesting that the cross product E×H points radially and that H is proportional to the radius (r).
  • Some participants propose setting up cylindrical coordinates to analyze the fields and the Poynting vector more clearly.
  • A participant argues that just because a vector field is zero at a point does not imply that its divergence is zero, using a mathematical analogy to illustrate this point.
  • There is a suggestion that the divergence of the Poynting vector should be uniform across the cross-sectional area of the wire, assuming J·E is uniform.
  • One participant mentions the need to solve the magnetostatic equations completely for consistency with energy conservation and Poynting's theorem.
  • Several participants discuss the mathematical treatment of the fields, including the application of the right-hand rule and the calculation of the divergence of the cross product E×B.
Participants express differing views on the behavior of the Poynting vector and its divergence in the context of a DC current-carrying wire. There is no consensus on the resolution of the contradictions presented, and multiple competing interpretations remain active in the discussion.
Participants highlight the importance of correctly applying mathematical principles in cylindrical coordinates and the implications of assumptions regarding uniformity in the electric field and current density. Some mathematical steps and assumptions remain unresolved, contributing to the ongoing debate.
thatsmessedup
According to equation (2.33) divergence of the Poynting vector or the outflow of electromagnetic power is equal to the stored magnetic field, stored electric field and ohmic losses.
My contradiction is the following:
Inside a steady state DC current carrying wire, there will presumably be a uniform e-field (E) in the direction of current, and also a steady current density (J) in the direction of current. Therefore equation (2.33) should not be zero because the term J dot E will not be zero.
Now, according to ampere law, in the center of a conductor, the magnetic field should be zero.
Therefore, the Poynting vector, equation (2.36), at the center of the conductor will be zero and the divergence of the Poynting vector will also be zero. In conclusion, at the center of the wire, using equation (2.33) the left side equals to zero (del(ExH)=0), but the right side equal to non zero (J dot E = non zero). What am I missing? Thank you for your help!
Why is the divergence zero? E×H points in the radial direction and H is proportional to r.
Set up cylindrical coordinates.
## \bf E = ? ##
## \bf H = ? ##
## \bf P = \bf E \times \bf H = ? ##
Then get ## \bf P ## and ## \nabla \cdot \bf P ##
At the center of the wire, the H field is 0 and so ExH is zero, hence the divergence is also zero.
This is incorrect. The divergence is a measure of spatial change. H is non-zero for 0+ and consequently has a non-zero derivative.
Not true. Just because a vector field is zero at a point does not mean that its divergence is zero at that point. Think of a 1D example like y=x^2 - 4. y is zero at x=2, but dy/dx is not zero at x=2. Similarly for a vector field. In this case you have a vector field in cylindrical coordinates that looks like [itex]\lambda r e_r[/itex], where λ is some constant. If you take the divergence, you will find it is non-zero.
I think I'm rusty with my math skills. It all makes sense that there should be divergence in the center of the conductor as this is where all the Poynting vectors point. I need to whip out my old notes.
I am assuming that J dot E is uniform in the cross sectional area of the wire. So, if I get the math right and find the divergence of ExH at different points on the cross sectional area, should I expect all the values to be the same? I mean, this seems to be the obvious conclusion.
## \bf j \cdot \bf E ## is uniform everywhere. Ohm's law applied to electric fields is ## \bf j = \sigma \bf E ## and applies at every point inside the wire. ## \sigma ## is conductivity.
Yes, ## \nabla \cdot \bf P ## is uniform across the cross-sectional surface, in fact everywhere in the wire if it's long. As you can determine and calculate per my post 3.
The problem is that you didn't solve the magnetostatic equations for the coaxial cable completely. If you do so, you'll find that everything is consistent with energy conservation and Poynting's theorem. For a complete thorough discussion see Sommerfeld, Lectures on Theoretical Physics, vol. 3.
## \bf E = ? ##
## \bf H = ? ##
Lol... Its been a few years since I've needed to do cross products on cylindrical coordinates. I wish I could remember how to do them. My EE notes look more like hieroglyphs at this point.
Welcome to the club! :-)
Given vectors in cyl. coordinates
## \bf A = a_1 \hat {\bf r } + a_2 \hat {\bf \theta} + a_3 \hat{\bf k} ##
and ## \bf B = b_1 \hat{\bf r} + b_2 ... ## etc.
form the determinant
1st row : ## ~~ \hat {\bf r} ~~ \hat {\bf \theta} ~~ \hat {\bf k} ##
2nd row: ## ~~ a_1 ~~ a_2 ~~ a_3 ##
3rd row: ## ~~ b_1 ~~ b_2 ~~ b_3 ##
then determinant = ## \bf A \times \bf B ##.
(I tried to use the LaTex determinant but failed).
I think you're overcomplicating it. E points down the wire with constant magnitude, so [itex]E = E_0 e_z[/itex]. B wraps around the wire with a magnitude proportional to r, so [itex]B = B_0 r e_{\phi}[/itex]. Just apply the right hand rule, and ExB is perpendicular to both of them, and so must be [itex]E \times B = E_0 B_0 r e_r[/itex]. Then [itex]\nabla \centerdot (E \times B) = \frac{1}{r} \frac{\partial}{\partial r}(r (E \times B)_r) = 2 E_0 B_0[/itex]
Make that ## - 2E_0B_0. and you have a deal. The determinant knows the difference.
Right on! Thanks for the math help and I guess its not so bad after all.
Yep, the unit vector should be negative since the cross product points inward. It also makes sense because a resistive wire should have an inflow of electromagnetic power and the divergence of a vector represents outflow. Thanks for your help!
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 23 ·
