Fortran Help with fortran numerical precision
The discussion revolves around a Fortran code issue related to achieving double numerical precision in a normalization calculation. The user, Cayo, is experiencing a result of 0.999998932390816 instead of the expected 1.0. A key point raised is that while the code uses `real(kind=8)` to denote double precision, this does not guarantee consistent implementation across different compilers, as the Fortran standard allows for compiler-dependent behavior. Another contributor suggests ensuring all variables are declared with a consistent precision by defining a parameter for double precision. However, Cayo reports that this change did not resolve the issue. The discussion highlights that the discrepancy arises from approximating an integral over a finite grid, which inherently leads to inaccuracies. Ultimately, Cayo acknowledges that the grid size is too small, confirming that this limitation is the root cause of the unexpected normalization result.
Cayo
Hello. I need help to understand why my code is not giving me double numerical precision.
In this piece of code, I create a function that is analytically normalized, but when I calculate the numerical normalization factor, it seems to be with single precision. Here it is:
Fortran:
program dyna
implicit none
integer i
integer, parameter :: Nq1=61
real(kind=8), parameter :: saw2au=1822.889950851334d0
real(kind=8), parameter :: nitro=14.0067d0*saw2au
real(kind=8), parameter :: mredu=nitro**2.0d0/(2.0d0*nitro)
real(kind=8) :: e0,pi,ch,x,x0,stepX,w,expo,c0,c1
complex(kind=8) :: soma,vec0(Nq1)
pi = 3.141592653589793d0
e0=0.005d0
x0=2.09970623d0
stepX=0.01d0
w=2.d0*e0
c0 = ((mredu*w)/pi)**(1.d0/4.d0)
c1 = (4.d0/pi*(mredu*w)**3.d0)**(1.d0/4.d0)
do i=1,Nq1
  ch=(i-(Nq1-1.d0)/2.d0-1.d0)*stepX
  x=x0+ch
  expo = dexp(-(x-x0)**2.d0*mredu*w/2.d0)
  vec0(i) = c0 * expo
end do
!normalizing                             !
soma=0.0d0                               !
do i=1,Nq1                               !
  soma=soma+conjg(vec0(i))*vec0(i)*stepX !
end do                                   !
vec0=vec0/sqrt(soma)                     !
write(*,'(a24,2(f23.15))')'normalization constant =',soma
end program
I get 0.999998932390816, and it should be 1.0d0.
I use complex vectors because later in the code they will become complex.
I don't understand where is the problem. Can someone help me, please?
Thanks in advance,
Cayo
Technology news on Phys.org
kind=8 doesn't guarantee that you will get double precision. The Fortran 90 standard doesn't specify how kind is to be implemented, so it is compiler-dependent.
If you want to insure that all variables are declared as double precision, you can use
Fortran:
integer, parameter :: dp = kind(1.d0)
real(kind=dp) :: x
complex(kind=dp) :: z
Thank you for the reply, you are correct.
But, I changed what you suggested and it didn't changed the result. Any other idea?
I looked at your code in more details, and I don't understand why you say that
Cayo said:
it should be 1.0d0.
You are approximating an integral from ##-\infty## to ##\infty## using a finite grid. Why would you expect that to be an exact? Check the values of vec0(1) and vec0(Nq1).
Hello DrClaude,
You are right. Thats the problem, the size of the grid is too small. Thank you for the help.
Dear Peeps I have posted a few questions about programing on this sectio of the PF forum. I want to ask you veterans how you folks learn program in assembly and about computer architecture for the x86 family. In addition to finish learning C, I am also reading the book From bits to Gates to C and Beyond. In the book, it uses the mini LC3 assembly language. I also have books on assembly programming and computer architecture. The few famous ones i have are Computer Organization and...
I have a quick questions. I am going through a book on C programming on my own. Afterwards, I plan to go through something call data structures and algorithms on my own also in C. I also need to learn C++, Matlab and for personal interest Haskell. For the two topic of data structures and algorithms, I understand there are standard ones across all programming languages. After learning it through C, what would be the biggest issue when trying to implement the same data...
