HELP with Killing Vectors in AdS
  • Context: Graduate
  • Thread starter Thread starter llorgos
    Vectors
The discussion focuses on finding the Killing vectors of the Anti-de Sitter (AdS) metric defined by the equation dsd+12 = (dz2 - dt2 + dxidxi)/z2. Participants clarify that after computing the Christoffel symbols, one can apply Killing's equation, ∇aXb + ∇bXa = 0, leading to a system of differential equations to solve for the components of the Killing vector field, Xa. The conclusion emphasizes that the Killing vector field can be expressed simply as X = Xaa, where ∂a denotes the coordinate frame.
  • Understanding of the Anti-de Sitter (AdS) metric
  • Familiarity with Christoffel symbols in differential geometry
  • Knowledge of Killing's equation and its implications
  • Basic concepts of vector fields on manifolds
  • Study the derivation of Christoffel symbols for various metrics
  • Learn how to solve differential equations arising from Killing's equation
  • Explore the properties of vector fields in differential geometry
  • Investigate applications of Killing vectors in theoretical physics
The discussion is beneficial for theoretical physicists, mathematicians specializing in differential geometry, and students studying general relativity or related fields who are interested in the properties of Killing vectors in the context of the Anti-de Sitter space.
llorgos
Hi and I am sorry if you find my question naive.
I have to find the Killing vectors of the AdS metric
ds_{d+1}^{2} = \frac{dz^2 - dt^2 + dx^idx^i}{z^2}
I have found the Christoffel symbols. If I use the Killing's equation \nabla_{a}X^{b} + \nabla_{b}X^{a} = 0 I find a set of differential equations. Ok, then supposing I can solve them I get components of vectors, e.g. X_{z} = ze^{c}. So this is a component of the Killing vector?
I am quite confused and I would appreciate if someone could explain in simple steps how to proceed.
Thank you very much for your help and patience.
The metric you have, the ##ds_{d+1}^2##, gives you the components of the metric, ##g_{ab}##, which you can just read off. Feeding this into the Christoffel symbols and the Killing equation gives a system of differential equations which you solve for ##X^a##. I think you've got this far.
I think you may be confused because the ##X^a##'s are functions? Correct me if I'm wrong.
These ##X^a## should be functions on the manifold, since they correspond to the components of a vector field on it. Thus, the Killing vector field is just (locally, that is, in the coordinate system specified) ##X=X^a\partial_a##, where ##\partial_a## is the coordinate frame (I'm not sure how physicists do their notation).
Yes. I get the X_a's or X^a's. I know they are funcitons on the Manifold. The thing is, do I just say, ok, the the vector field is just X = X^a \partial_a?
Is it that simple?
Yep. It's that simple.
Ok. Thank you very much. Let's see if I can make any progress.
  • · Replies 0 ·
