Help with Relativistic Collision
SamRoss
I'm stuck trying to complete this derivation of relativistic momentum without reverting to relativistic mass (a concept I don't like). Those who have read Richard Feynman's "Six Not So Easy Pieces" will realize that I'm really just taking his setup but instead of introducing relativistic mass to maintain conservation of momentum I'm trying to redo the end without it. Maybe someone can help.
I start with two identical billiard balls moving diagonally towards each other and then bouncing off in an elastic collision. The motion can be thought of as forming an "X" shape where the top "v" is ball #1 moving, let's say, down left and then up left. The bottom upside down "v" is ball #2 moving up right and then down right.
If the collision is seen by an observer moving horizontally to the right with the same horizontal velocity as ball #2 then to him the collision would look like a "Y". In other words, ball #2 simply moves up and down with no horizontal movement while ball #1 whizzes by even faster than before. For this observer, it is clear from the picture that horizontal momentum is conserved before and after the collision - ball #2 has no horizontal movement while the horizontal velocity of ball #1 is unchanged. This leaves us to check the conservation of vertical momentum.
Let w be the vertical velocity of ball #2. The vertical velocity of ball #1 can be determined by doing a composition of velocities. This turns out to be w\gamma-1(u) where u is the horizontal velocity of ball #1. Note the inverse gamma is a function of u as opposed to w. For simplicity's sake let's let w\gamma-1(u)=s.
Now we get to the last step and this is where I'm having trouble. My method is actually not so much to derive the relativistic momentum as it is to propose it and then show that it results in the conservation of momentum. If we propose \gammamv (m being invariant mass) then the change in vertical momentum of ball #2 before and after the collision should be 2\gamma(w)mw while the change in vertical momentum of ball #1 is 2\gamma(s)ms.
I would think that these two things should be equal but it's not turning out that way on my paper. Am I just making a careless error and these things really are equal or is there something wrong with my reasoning?
You can always replace relativistic mass with the energy or use ##\gamma m##.
The inverse gamma function of a velocity doesn't make sense. The gamma function assigns a real number to a velocity, the inverse would assign a velocity to a real number. Plugging in a velocity can't be meaningful.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
