Help with reverse siphon break?
  • Thread starter Thread starter Raavin
    Break Reverse
The discussion centers on creating a reverse siphon system that allows a liquid to siphon into a smaller container and stop automatically when the liquid reaches the level of the tube opening, without using valves. Raavin seeks a solution to minimize moving parts, and Cliff suggests making the larger container airtight, allowing air to displace the liquid as it drains. This method is likened to gas cans and pet water feeders, which utilize similar principles to control liquid flow based on air displacement.
  • Understanding of siphoning and capillary effects
  • Knowledge of fluid dynamics principles
  • Familiarity with airtight container design
  • Experience with liquid transfer systems
  • Research the principles of fluid dynamics in siphoning systems
  • Explore designs for airtight containers and their applications
  • Investigate capillary action and its role in liquid transfer
  • Examine existing products like pet water feeders for practical insights
Engineers, hobbyists, and anyone interested in fluid mechanics or designing liquid transfer systems without mechanical components.
Raavin
Hey there,
Not sure if this is possible but...
I was wondering if there was a way to set something up so that one liquid would siphon into a lower container and stop when the liquid reached the level of the tube opening without using any sort of valve?
Basically I need a large volume of liquid to feed into a small volume bottle then shut off when the smaller bottle gets to a certain level. I think there may be a way to do it using either or both the siphoning effect and capillary effect.
The main point is to minimise (actually eliminate) moving parts like valves.
Any ideas?
Raavin
You could just make the larger container air-tight. Now as the liquid drains from it through the tube, it gurgules as the air goes back up the tube to make up the displacement of liquid removed. Once the liquid reaches the level of the tube opening, no more air is available to allow any more liquid to be displaced.
I have a gas can for my lawn mower that works this way. It works ok. With something of a higher viscosity and a smaller opening it would work better, like trying to get motor oil out of those plastic bottles if you tip them completely upside-down instead of pouring them into the funnel.
HTH
Cliff
To do it once, is feasable, repetitions are another story...
Mmmm, yes, that might just work. For some reason I was getting stuck on the larger container 'siphoning' the fluid out rather than taking the feed tube out of the bottom of the container. Now that I think about it, you can get pet water feeders that you attach an inverted bottle to and it feeds in water when the water gets below the level of the opening.
Nice work Cliff_J. I'll have to get experimenting.
Cheers,
Raavin :D
  • · Replies 17 ·
  • · Replies 42 ·
21K
  • · Replies 27 ·
  • · Replies 28 ·
