Simple Summations Help: Solving 6n+8 with Index i=4
  • Thread starter Thread starter theintarnets
The discussion revolves around solving the summation of 6n + 8 with an index starting at i=4. The user expresses confusion about how to apply the summation formulas, particularly regarding the separation of terms and the use of constants. Clarification is sought on whether to use the index value of 4 or another constant when calculating the sum. Participants suggest that the user should consider the relationship between the index and the summation limits, specifically how to adjust the sum to start from i=4. The conversation emphasizes the importance of understanding how to modify summation limits to correctly compute the desired sum.
theintarnets
I forgot how to do summations... I've been googling all day, but I can't find resources good enough for the types of problems I have. If anyone can provide me with some resources, I'd really appreciate it.
Ʃ6n+8
i=4
I'm just going to call that S
Ʃ of i = 1 to n is n(n+1)/2
I know I can separate the two terms:
S6n + S8
And then pull the constants out?
6n*S1 + 8S1
But can I use 1 as the new constant or do I have to use 4 since that is the index? Do I just multiply 4 by 10087? Or 1 by 10087 and then subtract... something? I don't know, the index of 4 is really throwing me off.
It's not clear what you are trying to sum.
The summation you have is indexed by 'i', but the summand uses 'n'. Is there some relationship between 'i' and 'n' which you have not posted?
If you have a formula for a sum which goes from 'i' to 'n', how would you use that formula if 'i' starts at 4?
Hint: write out the terms of a sum which starts at 1 and goes through say i = 5. How would you modify the sum so that the first term is for i = 4?
I know that there's no relationship between i and n, which is why I'm so lost. If I was using i, and it started at 4, would I just subtract the sum of 1 to 3?
Of course.
