Help with solving first order ODE using a simple Fortran code, please
The discussion revolves around solving a first-order ordinary differential equation (ODE) using Fortran code. Participants explore the integration of the ODE and the plotting of the results, specifically how to obtain a single plot of the variable \( s \) as a function of \( h \) over time.
  • Homework-related
  • One participant presents the ODE \( \frac{ds}{dt} = k_i \sqrt{v} \) and defines \( k_i \) and \( v \) in terms of other variables, indicating that \( h \) changes from 100 to 1.
  • Another participant points out that the write statement is located within an inner loop, leading to excessive writes and increments of \( s \) for each time step.
  • A participant expresses the intention to plot \( s \) against \( h \) over a long time period, suggesting that \( s \) represents a material's strength and \( h \) represents height.
  • One suggestion is made to swap the loops in the code and reset \( t \) to 0 in the outer loop to achieve the desired plotting of \( s(t) \) with \( h \) as a parameter.
Participants generally agree on the need to adjust the loop structure in the code to achieve the desired output, but there is no consensus on the exact implementation details or the implications of the changes suggested.
There are unresolved aspects regarding the integration steps and the specific values for the constants involved in the ODE, which may affect the results and plotting.
joseph2015
New user has been reminded to use the Template when posting schoolwork problems
I am trying to solve the following first order ODE using a simple Fortran code :
$$ ds/dt=k_i * \sqrt{v}$$
where both (ki) and (v) are variables depending on (h) as follows
$$ k_i=\sqrt{χ/h^2}$$
$$v= \mu h$$
where (μ) and (χ) are constants. (the arbitrary values of each of them can be seen from the code attached).
Note: h changes from 100 to 1 with -1 reduction
Now after writing the code, I would like to plot (s) as a function of (h). but what I will get is not a single plot, but a series of plots depending on the number of timesteps. the issue has to do with loops, but I am not sure how to get a single plot of (s) against (h) as it grows over a period of time.
Fortran:
program height
    implicit none
    double precision ki, t, v, s, a, x, tend, dt
    integer count,h,nstep
    real mu
    REAL, PARAMETER :: Pi = 3.1415927
    tend   = 100
    dt     = 10
    nstep  = tend/dt
    write(*,*) 'end time for the integration: ', tend
    write(*,*) 'integration time step: ', dt
    write(*,*) 'number of time steps: ', nstep
    open(30, file='height.agr')
    x      = 1.99
    s      = 1.0e-2
    mu     = 2.34
    t      = 0.0
    write(30,*) s, real(h*1.8e+4)
    ! START to Integrate.
    write(*,*) 'Start time integration (', nstep, ' steps) ...'
    do count = 1, nstep
        ! update the time
        t = t + dt
       do h  =100,1,-1
          v  =mu*h
          ki =sqrt((x)/h**2)
          a  = ki*sqrt(v)
          s  = s+dt*a
            write(30,*) s, real(h)
       end do
    end do
    write(*,*) 'end'
    close(30)
    100  format(d14.8,1x,d14.8)
end program height
Your write statement is in an inner loop, so you get 100 writes for every time step.
What's worse, s is incremented 100 times for every time step too.
And the outer loop is done only 10 times.
What is it you want to do ?
Thank you very much for your answer
I am trying to follow the change of s as a function of time and h, then plot s vs h.
for example: if s is a strength of a material, while h is height (from 100 to 1cm), I would like to plot s vs h for 100 years time.
Kind regards,
Joseph
My guess is you want to swap the loops and reset t to 0 in the outer loop. That way you get s(t) with h as a parameter.
And I'd do 100 steps in t and 10 steps in h.
And with double $ to delimit the ##\TeX## source you get displayed math:
$$ \frac {ds}{dt}=k_i \sqrt v$$ $$ k_i=\sqrt{\chi/h^2}=\frac {\sqrt \chi }{h } $$
I will try that, thank you very much
