Help with temperature and Pressure
12 replies · 4K views
hippyhoppy
Ok, please could somebody give me some guidence on how to answer this question!
An air bed is pumped up and left on the beach on a warm day. The pressure of the air in the air bed is 105 kPa when the temperature is 17 degrees c. What is the pressure when the temperature on the beach has risen to 37 degrees c.
Many thanks in advance for your help!
Sorry about that! I am not really too sure - this is what i was stuck on, the only thing i could think of is PV=nRT but i don't see how its relevant
The ideal gas law is extremely relevant. As the balloon heats up, which of the five quantities that appear in the gas law remain constant and which change?
Temperature changes?
Sorry I am not sure about velocity...
n stays the same
R will stay constant
Sorry, physics isn't my strong Point! Ok, The pressure increases as it always does with temperature as with p/t= constant right? Again, volume I am not too sure but i would guess that the voulume would stay the same. I am fairly sure the number of moles will stay the same, to be honest I've never been taught the Universal Gas Constant, so wouldn't know and the temperature is increasing. Sorry i don't know much.
You are doing fine. R is constant, that's why it is called that, n the number of moles will change only if gas entered or left the balloon (which it does not) and the volume cannot appreciably change when the temperature changes only by 20 degrees.
So you are correct in saying p/T = constant. This means that pressure divided by temperature when the temperature is 17 Celsius is the same as pressure divided by temperature when the temperature is 37 degrees Celsius. Can you say this with an equation and put in some numbers? Don't forget to convert the temperature from Celsius to Kelvin.
Sorry i am confused! Do you mean that i put the equation like this:
105/37? Sorry you must be getting annoyed!
Sorry I am confused as to which equation.
p/t=constant or PV=nRT
Sorry, i get the Kelvin and Pa Part
Can anyone help please!
