Help with thermodynamics -- work of Carnot engine expansion
The discussion revolves around the calculation of work during the isentropic expansion of a Carnot engine, specifically addressing the confusion regarding the application of the first law of thermodynamics and the relationship between changes in internal energy and work done. The context is primarily homework-related, focusing on thermodynamic principles and the Carnot cycle.
  • Homework-related
  • One participant expresses confusion about calculating work for the isentropic expansion (2-3) of a Carnot engine, initially considering the entire process from 1-3, which includes isothermal expansion.
  • Another participant agrees with the initial claim that the change in internal energy from 1-3 is the same as from 2-3, but questions how this relates to the work done.
  • A clarification is made that the work for the isentropic expansion (2-3) must be calculated independently, noting that it equals the negative of the change in internal energy due to zero heat input.
  • There is a discussion about ensuring that internal energy calculations are consistent in units, specifically that both change in internal energy and work should be expressed in kilojoules.
Participants do not reach a consensus on the clarity of the relationship between the changes in internal energy and work done. There are varying interpretations of the application of the first law of thermodynamics in this context, indicating some disagreement or uncertainty.
There are limitations regarding the assumptions made about the Carnot cycle, particularly the distinction between adiabatic and isothermal processes, and the implications for calculating work and internal energy changes.
nate9519
I don't need help solving I just need some clarification. Since the carnot cycle is adiabatic, the first law would reduce to work= mass*(change in internal energy). On my test I was asked to calculate the work of the isentropic expansion of a carnot engine with air as the working fluid. I got confused and calculated from step 1-3( isothermal expansion and isentropic expansion) instead of 2-3( just isentropic expansion.) But since step 1-2 is isothermal would that mean the change in internal energy from 1-3 is the same as 2-3 meaning I would still have gotten the right answer
Science news on Phys.org
Sure.
I need some clarification of the steps involved here. You were asked to calculate the Work during the isentropic expansion (2 - 3). You are saying the change in internal energy from 1 - 3 is the same as the change in internal energy from 2 - 3. I agree with your statement, but how is it related to the work? Your statement: "Since the carnot cycle is adiabatic, the first law would reduce to work= mass*(change in internal energy)." is very confusing. Are you talking about the entire Carnot cycle (1 - 2 - 3 - 4 - 1)? The entire cycle is not adiabatic, and the total change in internal energy for the entire cycle is zero, and that is not related to the work done.
sorry for confusion. No I didn't mean the entire cycle is adiabatic. I meant from 2-3. My book uses a piston cylinder to demonstrate the carnot cycle and since that is a closed system I thought the first law reduces to mass*(change in internal energy) for the work from 2-3
OK. So the work from 2-3 (adiabatic expansion) needs to be calculated independently. It is still equal to the negative of the change in internal energy, because the heat input is zero.
yes and that would give you an answer in kilojoules per unit mass. But the problem stated that the working fluid was 15kg of air so if I multiplied delta u by 15kg to get the answer in kJ that would be correct as well, right?
Make sure that the internal energy is calculated in the same units. Both the quantities, change in internal energy and work must come out in kJ.
15K
9K
