Help With Units in General Relativity
  • Context: High School
  • Thread starter Thread starter needved
    Units
2 replies · 1K views
needved
Hi people :)
I'm learning some of General Relativity topics but still I am a beginer, uh! i use the Schutz "A first course of general relativity", but i a little confused about the units, the author say it use c = G = 1 all around the book.
Just right now i reading chapter 11: Schwarchild Geometry and Black Holes". especifically "Conserved quantities" unit, and there, there is a couple of graphs V(r) vs r and in both graphs the root is "r = 2M" where M is the mass of the Schwarchild Black Hole, so my question is how i recover the original lenghts units? i mean if M =1000M(Sun) then i can't say the distance r is 2000M(Sun).
Thanks in advance
(Sorry if a silly question :frown: )
The mass ##M## in length units can be found by taking the mass ##M_{\text{conv}}## in conventional units and applying the formula:
M = \frac{G M_{\text{conv}}}{c^2}
where ##G## is Newton's gravitational constant and ##c## is the speed of light. Basically, the mass ##M## in "length units" is the mass in a system of units in which ##G = c = 1##; in this system mass and length have the same units.
More generally, dimensional analysis. You want a length (dimension ##L##), you've got a mass (dimension ##M##), and you only have G (dimension ##M^{-1}L^3T^{-2}##) and c (dimension ##LT^{-1}##) to play with. You need to multiply by ##G^ac^b## (##a## and ##b## are powers, not tensor indices) such that the dimensions match.
In this case, you have ##r=G^ac^bM##, the dimensions of which are ##L=M^{-a}L^{3a}T^{-2a}L^bT^{-b}M##. Comparing powers of M, L, T gives you
M: ##0=-a+1##
L: ##1=3a+b##
T: ##0=-2a-b##
any pair of which solves to give you Peter's answer.
Informally, stick the SI units into what you have and multiply/divide by powers of G and c until they match.
