High Current Switch Solution for Hobbiest
  • Thread starter Thread starter babyd3k
    Current Switch
Hobbiests are seeking a rotary switching system to alternate between a 1000W DC power supply and an external supply, with a requirement for an all-off position. The challenge lies in finding a rotary switch that can handle the high current of 83A, which is comparable to welding currents and requires specialized equipment. While relays and semiconductors can manage such loads, they are costly and complex to design. An alternative solution is to switch power supplies only when they are not under load, which simplifies the process significantly. A double pole double throw knife switch could effectively meet this need without the complications of high current switching.
babyd3k
Hobbiest here trying to make a rotary switching system to switch between a 1000w DC power supply and an external DC supply of the same input plus an all turned off position. The first power supply is running at 12 vDC and the 2nd input could be anything from 8-36 vDC. I can find rotary switches that have the positions and layouts I want but nothing that can handle the loads I would put the switch under.
I guess my question is what would a real engineer do, I was thinking of putting a solenoid in but I don't have any experience with then so before I bit off more then I could chew I thought I'd come ask the experts.
Thanks in advance.
babyd3k,
Welcome to PF!
1000W @ 12Vdc is 83A! Switching 83A is a non-trivial feat! 83A is in the welding range of currents, and needs special attention. There are relays capable of handling these kinds of currents, but they are expensive, very expensive. There are semiconductors capable of handling this amount of current, but the design criteria are difficult at best. I would seriously consider finding a solution that does not involve switching 83A under load. If you are simply interested in switching between power supplies when they are NOT under load the problem becomes much easier. A simple double pole double throw knife switch will do the job.
Fish
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
