High dielectric strength, vacuum compatible glue
The discussion revolves around finding a high dielectric strength adhesive suitable for bonding PTFE or Hostaphan to stainless steel in a vacuum chamber. Participants explore various adhesive options while considering vacuum compatibility and mechanical strength requirements.
  • One participant notes that bonding PTFE is challenging and may require surface treatment before adhesive application.
  • Several participants mention specific adhesives, including Loctite, Master Bond, 3M, and Torrseal, highlighting their vacuum compatibility and properties.
  • A participant expresses skepticism about Master Bond's performance relative to its cost.
  • Another participant suggests Cyberbond CA 2240 as effective for PTFE bonding.
  • Permabond ET538 is mentioned as a strong two-part epoxy, with one participant noting its dielectric strength of 15-25 kV/mm.
  • Participants share links to resources and articles regarding adhesives suitable for vacuum environments.
There is no consensus on a single adhesive solution, as participants propose different products and express varying levels of confidence in their effectiveness for the specific application.
Participants have noted the need for vacuum compatibility and high dielectric strength, but specific dielectric strength values for some suggested products remain unspecified. Additionally, there are concerns about the cost and performance of certain brands.
1Keenan
Hi all,
I would need an high dielectric strenght glue to fix PTFE or Hostaphan to the vacuum chamber wall in stainless steel, so the glue should be vacuum compatible.
Force against the bonding direction would be 50N, so if the glue has already 100N it would be good but I don't think it is an issue.
Any suggestion_
THank you
jrmichler said:
Bonding PTFE is not easy, it will require some sort of surface treatment first. A quick search using terms loctite adhesive vacuum found the following: https://www.idealvac.com/files/brochures/Loctite1CHysol_TechSheet.pdf. Master Bond and 3M also make low outgassing adhesives.
And here is a good article about adhesives for vacuum environments: https://www.machinedesign.com/fasteners/epoxies-and-adhesives-fit-space .
As in the above reply, Hysol 1C is a good adhesive for vacuum, and is very similar in its properties to Torrseal.
NASA also has a database which gives the outgassing properties of many different epoxies.
I have had good success with Torrseal, but I don't know if it will adhere to PTFE.
Thank you for the replies.
Well, vacuum compatibility is one property I need, but I also need high dielectrict strength.
I found a product form MasterBond with very high breakdown but I cannot find it anymore...
MasterBond is expensive, and in my experience, doesn't live up to the hype.
Cyberbond has a CA called 2240, that I often use. Works great on PTFE.
Another one I would try is Permabond ET538. It's a 2 part epoxy and it's extremely strong. we use it to adhere ceramic and PCB to steel.
I was checking Permabond web site. They have specific products for PTFE, but they do not specify dielectrict strenght.
Sent an email
Cheers
F.
Sent an email
Cheers
F.
The ET538 that i use has a Dielectric Strength 15-25 kV / mm
that would be good!
  • · Replies 99 ·
11K
  • · Replies 42 ·
10K
10K
