marcusl said:
Yes I did and your statements
are incorrect--backwards, actually. The current is induced by the E field, and not the other way around. To use your words, the force that the electrons experience depends on the E field. The electrons set in motion by E constitute the current density.
Maybe I shouldn't have said "depend". But the field and the force on the electrons can certainly by derived from the current density. However that feels like splitting hairs. I mean is it incorrect to say e.g. that the voltage that drops over a resistor depends on the current?
russ_watters said:
What happens if your wire is charged to a very high voltage, but there is no current? Electrons will still spontaneously jump off of the wire because of the voltage. The existence of an electric field does not require the electrons to be moving. It does not require any current.
First off, the equation that I mentioned - J=σE - is always true in materials that obey Ohm's law. So field strength and current density always depend on each other. If you have a perfect insulator the current density is 0 but the law is not violated. Inside a metal wire you can't have an E field without a current, and you can't have a current without a field.
You said yourself that 1000 times the voltage means 1000 times the electric field. Now you're saying the electric field doesn't depend on the voltage!
I said the field INSIDE the wire doesn't depend on the voltage between the wire and ground which is not the same as the voltage across the wire. If you have 1V dropping over the wire and 1000V between the wire and ground, the current density and the field strength inside the wire will depend on that 1V that is dropping over the wire but not on the 1000V.
ealbers said:
Wow, the answers are great, I've heard the power is in the E field, obviously its not the magnetic field since that's dependant upon the number of electrons and in our simple example there only being 1 lonely electron B must be pretty small.
If you only have one single electron in your wire, that wire is not going to behave like a normal metal wire. You can not transmit an electric field along a wire with only one electron. You need a large number of them to do that.
How come I never hear about big E fields being around transmission lines? I mean, you can use a simple compass to 'see' the B field, but the E field seems well contained, is it fully 'in' the wire?
There are strong E fields between an hv transmission line and ground. In the case of AC, you can measure them with a simple multimeter with one lead connected to ground and the other to some form of antenna. (But please don't do any dangerous experiments)
Given a hypothetical 'super' insulator, you could transfer all the power a whole city needs using a single electron, in a tiny
diameter wire, now THATS cool...and curious...
Not with a single electron.
Are there 'visible' manifestations in that case of the E field 'leakage', I mean is there a way to detect this E field from outside the wire as its transmitting the power? I suppose the detection would act as a drain on the power.
You could measure the field that exists outside the wire with a field meter but it's usually different from the one inside the wire.
If you want to determine the field on the inside, all you have to do is measure the voltage that drops across the wire and divide it by the wire length. More important though is the field inside the load that's being powered. Because that is the one that transmits the power into the load.
