Higher Inverse Order O(n) Explained
  • Thread starter Thread starter terp.asessed
    Inverse
Higher inverse orders of n, represented as O(n), refer to the growth rate of algorithms in relation to input size. In big O notation, O(n) indicates a linear relationship where the time or space complexity increases proportionally with n. The term "order" signifies the power of 10, meaning O(1000) is order 3. Inverse order suggests a negative exponent, indicating a decrease in complexity as n increases. Understanding these concepts is crucial for analyzing algorithm efficiency and performance.
terp.asessed
What is higher inverse orders of n, as symbolized by O(n)? Please explain this to me---I am still confused even if googling it.
Mathematics news on Phys.org
O(n) would be "order of n". See "big O notation".
The "order" is the power of 10. So 1000 is order 3.
An inverse order would be the negative power of 10... but I need the context.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
