Highest element of the expression n^(1/n)
rahl__
how can I find the highest element of such set:
A={\sqrt[n]{n}:n\in{N}} ?
Mathematics news on Phys.org
Suggestion: You could look at \sqrt[x]{x}, \ \ x\geq 1
and find its absolute max, and then match the "corresponding" n.
Hint:
Find out where the maximum value is for real number arguments.
Since the function is increasing prior to the maximizing number, and decreasing afterwards, you only need to compare the function values of the integer just prior to the maximizing number and of the integer just after the maximizing number.
can i find where the maximum value is without using derivatives?
Try compering (n+1)^n and n^(n+1). The inequality canges after a certian number.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
