athrun200 said:
I know what is de broglie relation.
Can I use the relation like this?
But it seems it is wrong to convert dp to[tex]\Delta[/tex]p
But I have forgotten how to derive the HUP by using operators.
Can you show me how?
Hi, athrun, I'm trying to help:
1)i think your start is correct from deBroglie wave, you can take magnitude so negative sign will be gone (check Krane Modern Physics). if you start from p . x > h-bar (no divide by 2) and continue your calculation, it will proof it. But for the calculation, i think the author using h-bar / 2, if you want to get the same result.
2) you can start for (delta p) . (delta x) = h-bar / 2 (u can equal it for the minimum uncertainty), with (delta x) for uncertainty in ball's radius(delta r).
substitute for (delta x) = (delta D)/ 2 and (delta p) = m . (delta v) = m . (delta x)/ (delta t) = m . (delta D)/ 2 (delta t). with D = diameter.
you can simplify the equation to be (delta D)^2 = (2 . h-bar / m ) . delta t, and with (delta t) = sqrt(2 H / g).
Well, it slight different with your book about h there, but if you input it, u will get the same result as the key.
sorry if I'm using word for the equation (i don't know using tex in this forum)...
